Alternative Port EFI Intakes This board is for tech discussions and questions about aftermarket port EFI such as the HSR, MR, SR, BBK, FIRST, etc.
holley stealth ram question
Old Dec 24, 2008 | 02:37 PM
afida15's Avatar
I was looking at the hsr intakes and was curious if you get the manifold and the top manifold to what parts can you use from the tpi? what i mean is can you use all your tpi stuff on it if you just buy the intakes for the hsr?
Old Dec 24, 2008 | 02:50 PM
92droptopws6's Avatar
Car: '88 Trans Am
Engine: 5.7L TPI
Transmission: Slushbox
Re: holley stealth ram question
the throttle body will interchange
the stealthram and the TPI do not share the same fuel rails
Old Dec 28, 2008 | 09:25 AM
WASyL's Avatar
Car: 1988 Pontiac Firebird
Engine: 305 LT1 intake&heads
Transmission: TH700r4
Axle/Gears: 3.73 10bolt GM
only TB will fit - but what is sence to buy HSR and use stock TB, chage it to 2x58mm so that HSR will give what it should give
Old Jan 5, 2009 | 07:29 PM
vindeezl's Avatar
Car: '92 Z03
Engine: LSX
Transmission: M12
x2
The whole point of going HSR is to lose the TPI junk
9192camaro
16
Feb 3, 2019 12:21 AM
ASE doc
Aug 25, 2015 09:14 AM
theurge
Aug 21, 2015 12:46 PM
redmaroz
Aug 16, 2015 11:40 PM
L98GTA87
Aug 11, 2015 06:55 PM
