SR/Calmap 62 (really)... cuts out..ideas??
Car: 1983 Firebird SE
Engine: C5 LS1
Transmission: 6 speed
My 383 stops after about an hour or so. Wait 1/2 hour and it restarts.
My fuel tank doesn't breate right, so I thought it was that. Then it did the same thing with the gas cap loose.
It just stops running, like it has no fuel pressure. But even if the fuel pump cycles, it won't catch and run without waiting.
Fuel pump relay overheating??
ECU?
BTW, I run the Calmap from the floppy in DOS, good for grins.
Thanks-
ECU?
Thanks-
Car: 89 IrocZ/17 LS 1LE
Engine: 383/LGX
Transmission: 400/TR-3160
Axle/Gears: 3.08/3.27
Re: SR/Calmap 62 (really)... cuts out..ideas??
If the pump is priming I would think the relay is working. Have you checked the ignition control module?
Engine: C5 LS1
Yeah, that's it!
Other times, it just went slowly away. Yesterday, it did that signature..BLIP... then ran fine again. A minute later it went away quickly.
Accel Hi Po unit... high mystery too, I guess.
Pac J
May 17, 2020 10:44 AM
383backinblack
Oct 14, 2015 08:50 PM
