Alternative Port EFI Intakes This board is for tech discussions and questions about aftermarket port EFI such as the HSR, MR, SR, BBK, FIRST, etc.
HSR injectores?
Old Jun 12, 2009 | 01:15 AM
turbota82's Avatar
Car: 1989 Formula
Engine: l98
HSR injectores?
I just started my 412 sbc build. I useing a hsr and was wondering what brand and size injectors you guys would use. I was going to use a 30 lb injector and was thinking of Hawks. What do u guys think? Thanks!
Old Jun 12, 2009 | 03:06 AM
WASyL's Avatar
Car: 1988 Pontiac Firebird
Engine: 305 LT1 intake&heads
Transmission: TH700r4
Axle/Gears: 3.73 10bolt GM
Re: HSR injectores?
i use 30 lb Ford Racing, at stock fuel pressuer it makes 32 lb as ford gives their inj capability for diffrernt fuel pressure. they should siute for up to 400-420 HP
best regards
Old Jun 12, 2009 | 09:59 AM
GTA matt's Avatar
Car: 1990 GTA/1989 Iroc
Engine: L98/383
Transmission: 700r4/t56 magnum
Axle/Gears: 9"
Re: HSR injectores?
The ford 30 pounders are good up until about a 9.80 na motor
Old Jun 12, 2009 | 12:06 PM
irocuroc's Avatar
Car: 89 iroc
Engine: l98
Transmission: tremec
Re: HSR injectores?
JUST ORDERED THESE.. 100 CHEAPER THAN MOST I FOUND
http://fuelinjectorconnection.com/sh...&productId=210
Old Jun 12, 2009 | 09:16 PM
turbota82's Avatar
Car: 1989 Formula
Engine: l98
Re: HSR injectores?
thanks guys!!!!
Old Jun 23, 2009 | 10:35 AM
mrr23's Avatar
Car: 1986 pontiac TA
Engine: 360 HSR
Transmission: 700r4 3300 yank converter
Axle/Gears: 3.27 9 bolt
Re: HSR injectores?
personally i would use 36#
KCG
Jun 24, 2020 04:33 AM
92-Formula
Dec 12, 2015 10:34 PM
jerflash
Sep 24, 2015 03:11 PM
thejimsterz28
Sep 15, 2015 04:37 PM
webeeZ28
Sep 14, 2015 12:00 PM
