Alternative Port EFI Intakes This board is for tech discussions and questions about aftermarket port EFI such as the HSR, MR, SR, BBK, FIRST, etc.
HSR question
Old Jul 12, 2009 | 05:33 PM
thunder85's Avatar
Car: 1988 firebird trans am GTA
Engine: 5.7L w/hsr
Axle/Gears: posi 3.23
HSR question
Hello,
I have an 88 gta with original l98 (iron heads). when I look on summit and jegs, they don't list the weiand stealth ram as compatible. jegs is at least descriptive enough to say the 7540 kit (non vortec) is for 1957-86, 87 and up with aluminum heads. Is there a hsr intake kit for my engine or do i need to go to aluminum heads?
what reason would they have to exclude the iron head l98's from 87 and up?
thanks all... i'm sick to death of fighting with 20+ bolts and 7 gaskets on my tpi setup every time i need to change something or remove the plenum, etc.
thanks all
Old Jul 12, 2009 | 10:35 PM
wanta427's Avatar
Car: 1991 Z-28
Engine: 350 L98 al head Stealth Ram
Axle/Gears: 3.42 LS1 brakes
Re: HSR question
The HSR is set up for the early heads with all the bolts at the same angle . I think the holes are slotted for the late heads but you need to use the wedges to bolt the 4 centre bolts on . The other thing is the HSR has no EGR so if you need a visual for smog it won't pass .
Old Jul 13, 2009 | 02:45 AM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: HSR question
Because makers list parts as direct bolt on only.
Look at most SBC intake listings.
State "Fits 55-86 and Corvette alum heads" because the Vettes retained the old intake bolt angle.
If you are lucky, they will also list an identical intake as for "iron heads with centerbolt covers" because these came with the different bolt angle
They don't allow for the fact you can slot the holes on any SBC intake to fit the late iron heads.
Old Jul 13, 2009 | 05:51 AM
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
Re: HSR question
my hsr and the 2 others my friends have all have the 4 center holes slotted stock.
you don't need the wedged washers/spacers but I would reccommend using them so that the bolt heads will sit flush.
Old Jul 13, 2009 | 01:16 PM
wanta427's Avatar
Car: 1991 Z-28
Re: HSR question
go right to the bottom of this page http://www.fastpts.com/cgi-bin/hazel...ppsbchevy.html and it explains what we're talking about
355tpipickup
Aug 29, 2015 10:47 PM
ASE doc
Aug 25, 2015 09:14 AM
trevor1010
Aug 24, 2015 11:29 AM
355tpipickup
Aug 22, 2015 06:06 PM
redmaroz
Aug 16, 2015 11:40 PM
