Alternative Port EFI Intakes This board is for tech discussions and questions about aftermarket port EFI such as the HSR, MR, SR, BBK, FIRST, etc.
FIRST Fuel Injection TPI System
Old Oct 20, 2010 | 05:24 PM
  #51
1989GTATransAm's Avatar
Car: 1989 GTA
Engine: 369 TPI
Axle/Gears: 3.70 Nine Bolt
Re: FIRST Fuel Injection TPI System
1.What do you mean by exhaust termination boxes?
Here is an article by David Vizard on termination boxes or resonator boxes. You can do a goodle search on exhaust termination boxes. Plenty on the subject.
http://www.superchevy.com/technical/...xh/index1.html
2.My primaries are 1 5/8. Do you think it would be worth investing in Don's 1 3/4?
IMHO 1 5/8" headers are to small for a performance 383. I think Don's 1 3/4" headers would be an improvement because they are not only larger but they fit the wider AFR exhaust port better than any header on the market.
Old Oct 20, 2010 | 05:26 PM
  #52
spade's Avatar
Car: 1989 Mystery Firebird
Engine: 350 FIRST TPI
awesome thanx but id rather stick to maf then go sd...
Old Oct 20, 2010 | 05:27 PM
  #53
KyleWBooker's Avatar
Car: 1988 IROC Camaro
Engine: 383
Transmission: 700R4 built by Bookers Transmission
Yes that is Rbob's system. He has been very helpful with my long road of tuning and running into problems. He responds to emails very quickly. I would recommend this setup for the money and support if you ever want to change.
Old Oct 20, 2010 | 05:35 PM
  #54
Engine: 383
Im very interested in the headers. Are you running true duals or his Y pipe?
Old Oct 20, 2010 | 05:42 PM
  #55
Car: 1989 GTA
Engine: 369 TPI
The "Y" pipe but with a 3.5" Mufflex cat-back. Also a 3.5" Magnaflow muffler.
Old Oct 20, 2010 | 05:49 PM
  #56
Engine: 383
Thanks. I will have to contact Don sometime. If you have any undershots of your car, I would be interested in checking your set up out if you don't mind. If not, that is cool either way.
Old Oct 20, 2010 | 06:42 PM
  #57
Dyno Don's Avatar
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
It's similar to this but larger pipes/
Old Oct 20, 2010 | 06:50 PM
  #58
Car: 1989 GTA
Engine: 369 TPI
Yes. Thanks Don as I don't have a picture.
Old Oct 20, 2010 | 07:14 PM
  #59
Engine: 383
Looks good. I am running the single cat back with no cat at all because in Oklahoma there is no emissions at all. I am running no smog or anything.
Old Oct 20, 2010 | 10:36 PM
  #60
spade's Avatar
and back to FIRST we go...
Old Nov 18, 2010 | 12:11 PM
  #61
Engine: 383
Dyno Don, I am running the Headmen shorties on my car as of right now with 210 AFR heads. From what I can tell, your headers are built to match up to the AFR exhaust port?
Also If I were to install a set of your headers, would my existing Y pipe work or are the lengths different than most other headers?
Old May 18, 2011 | 08:45 PM
  #62
MrBeefy334's Avatar
Car: 1989 IROC-Z
Great informatino here, I'm sold on the FIRST system. It has everything I want. Low end tourqe, fat midrange, and good daily driver set up! awsome!
Old May 19, 2011 | 10:42 AM
  #63
Dyno Don's Avatar
Sorry, I wasn't keeping up with this thread.
No, the connections are totally different.
Each header and y-pipe combination are unique.
I was checking with Ken and he now makes an LT1 setup that uses a stock type throttle body (dual openings).
midge54
Dec 27, 2019 04:14 PM
9192camaro
16
Feb 3, 2019 12:21 AM
Fast355
Dec 2, 2016 06:33 PM
beachrodder
Aug 25, 2015 08:05 AM
86Base
Aug 13, 2015 05:06 PM
