Alternative Port EFI Intakes This board is for tech discussions and questions about aftermarket port EFI such as the HSR, MR, SR, BBK, FIRST, etc.
HSR to Single Plane..improvement?
Old Sep 6, 2009 | 10:59 AM
jonarotz's Avatar
Car: 91 Z28
This winter I am planning on puling out the motor and checking everything out. While it is out I am thinking about pulling an intake swap. It is a 355 with twin 62mm turbos on it. I am running 10:1 compression and around 10psi of boost. I currently am running a HSR with an Accel/Lingenfelter 1000cfm throttlebody. I am pleased with the setup but I would like to see if switching to a single plane intake with a 1550 throttle body would make anymore power. What do you guys think?
Here are my cam specs:
1987-1998 SR/HR ROLLER
DURATION @ .050 INTAKE 230 ROCKER ARM RATIO
DURATION @ .050 EXHAUST 236 INTAKE 1.50
VALVE LIFT INTAKE .510
VALVE LIFT EXHAUST .520
LOBE SEPARATION 114.0
INTAKE C/L 110.0
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
86IROC112
Nov 7, 2015 06:50 AM
Night rider327
Oct 9, 2015 09:25 AM
LT1Formula
Oct 8, 2015 08:34 PM
dusterbd
Sep 29, 2015 08:40 AM
