That "prototype" manifold...
Re: That "prototype" manifold...
Really? If anyone has that article I'd like to see it.
The manifold in the article may very well also be a ramport or something like on the callaway Twin Turbo 100+ setup.
Car: 1985 Camaro Z-28
Engine: 385
Transmission: th700r4+Edge 2800 stall
I found that article,but it isn't same manifold.The manifold at article was modified Edelbrock TR1Y tunnelram with tpi top and throttlebody.It was designed by Chevrolet engineers to 5 liter Camaro~275hp.It was -89 HRM january page 22.
Can you scan and post it??
Car: Manta Mirage
Engine: Donovan
Transmission: Porsche G50
Axle/Gears: 3.44 5-speed
On the subject of prototype manifolds, I thought I'd post a few pictures of a Trans-Am prototype that Falconer developed for Pontiac. I bought this one from Erik Falconer a couple of years ago.
Regards, Neil Tucson, AZ
nice!! in a selling mood?
sort of looks like the big block kinsler crossram originally designed for GT1/IMSA C3 Corvettes. It's not for a pontiac, it's for SBC pontiac motorsport heads from the looks of it. Sadly a lot of those heads are now hacked up beyond repair.
sort of looks like the big block kinsler crossram originally designed for GT1/IMSA C3 Corvettes. It's not for a pontiac, it's for SBC pontiac motorsport heads from the looks of it. Sadly a lot of those heads are now hacked up beyond repair. Supreme Member
Car: 85 2M6, 87 'Bird 88 'burb
Engine: LX9, LG4, L05
Transmission: F23, 700r4, 700R4
Axle/Gears: 3.63, 2.73, 4.10
Cool manifold, I was wondering what heads it used after looking at the bolt pattern. my quess is that it would perform similar to a TPI manifold with high flow runners.
Looks like it's for an 18 degree head setup. It looks like they used a normal spider type 18deg manifold (carbed), machined the whole spider off and attached the 4 elbows with small countersunk allen heads.
Car: Manta Mirage
Engine: Donovan
Yes, it is for Pontiac heads on a SBC-- I should have been clearer on that. I haven't bolted it onto anything yet but I do have a set of 18 degree heads so I might try it when I have time. Here are a few more pictures, including one with the port size marked on it.
Yes, it was originally for webers, it's modified. There are versions without the throttle blades and no injectors.
No brand, they were listed on ebay. don't think they are anymore.
Car: Manta Mirage
Engine: Donovan
Twin Turbo, you are right-- I checked the casting number of an 18 degree intake manifold and it is the same as the one on the Falconer manifold.
Car: 87 Callaway/90 Zr-1/92 ZR-1
Engine: TT TPI/LT-5
Transmission: 4+3/ZF-6
Axle/Gears: 2.73/3.45/4:09
any more info on this intake or feeback on performance? I just bought one of these for my 87 Callaway TT.
Engine: 4++,350 & 305 CIs
It also is the same kind of basic shape as the inside of the Firehawk T-ram
That's it, a mcfarland short ram.
Want to sell it?
Want to sell it?
Engine: TT TPI/LT-5
So is this a prototype? Was it for GM or Edelbrock? Does it flow well with TPI heads, getting it PC'd wrinkle black and then putting it on my 87 Callaway TT
thanks
Lee
thanks
Lee
I'm not sure who it was for but supposedly there is only 3 of them.. It would be nice to have it copied so it can be sold !!
It's aMcFarland short ram, McFaland had his own line of manifolds, like the torque link and some others. It's not a prototype but it's a very rare intake. Yours is not 1 of the 2 new ones off ebay so that makes it 4 confirmed in total. Mine has been modified but has the correct fuel rails, bolts and what not. The 2 new ones were bare, 1 came with an EGR setup (JerryWho's) the other was just a bare base & top. Looks like yours was actually used and cleaned up. Can you tell where you got it?
PCed black it would look like a Callaway 100+ intake,...nice!
Engine: TT TPI/LT-5
Guy I bought this from said in testing this intake was making more power all the way to 7K and it outflowed a custom Tunnel Ram and the SLP T-Ram
Engine: TT TPI/LT-5
Checked in with John Heinricy and he said that the intake looked like a prototype for the 1LE Camaro...got scratched for the LT-1 motor
Car: 88 Trans Am Hardtop
Engine: 350 L98
Transmission: Stock 700R4
Axle/Gears: 3.27 Aussie 9
Engine: TT TPI/LT-5
Getting close to finishing my 87 Callaway TT:
Stock IHI RHB52W Turbos
Ported Stock Heads
2.00/1.55 Valves
Ported Exhaust Manifolds
3" Exhaust
GM prototype 1LE Intake(Mcfarland Short Ram)
Small Cap Dist
Mocked up the Intercoolers to check fuel line clearances:
Ported Stock Heads
2.00/1.55 Valves
3" Exhaust
Small Cap Dist
Car: 1989 Trans Am GTA
Transmission: M28 T56
Words.....are..insufficient.
VERY VERY COOL !!!!!
Engine: TT TPI/LT-5
Will keep you posted on the progress...appreciate all the help from 3rd Gen, you are a great group.
Awesome, to a novice that would pass off as a 100+ for sure. I assume that's why you wrinkled it black??
Engine: TT TPI/LT-5
Found out one of the ZR-1 guys knows Jim McFarland......going to get the entire story on the intake
Please post it here
I'd like to know exactly what I have also.
thanks!
Marck
I'd like to know exactly what I have also. thanks!
Marck
Engine: TT TPI/LT-5
Waiting to get moredetail, but Mr. McFarland confirmed this was a GM contract piece, there were 6 made...all I have so far will see if I can get more details.....
I am trying to get info on the perf objective and what dyno results they got as well as confirm the 1LE
See if he can have more made!!
Car: 1990 G92 IROC Z Miniram
Engine: 388cu 6.4 Liters
Transmission: G-Force T5
Axle/Gears: 3.73 Gears
That would have been the best intake ever made for TPI. Wouldn't even need an after market company to make it.
It would be cool if one of these guys with that intake show to Edelbrock, BBK, Holley and see if they can copy it and put it into production. They will sell like ***** cats. A cool direct replacement.
No copies!! no copies!! Cant have true art copied LOL
HSR comparison pics
HSR comparison pics
This manifold is a lot more lively dow low than a miniram, I like it a whole lot better. Iy easily revs my 355 to 6K rpm, haven't done a dyno pull but it feels much happer up high. If you want to loose TQ get a miniram... it loses a LOT!
Is JerryWho still working on his? If he wants to sell..have him contact me LOL I could use a 2nd one.
If your wanting to build a torquey motor, you shouldnt even be looking at a short runner intake!!
Short runner intakes are for large CI motors with big stroke cranks.. The extra stroke helps pickup that "lost tq".
Quite honestly, my motor only spends time at 2500k rpm going down the road, but when I hit the throttle, it spins to 3500-4k rpm and just pulls like a freight train to 8k rpm.
The joys of a stroked and poked n/a 400ci motor.
I do think I would like to have one of those Mcfarland intakes, def over the ugly, to tall for the stock firebird hood, HSR and maybe even over the mini-ram.
I like the fact that it has a VERY production like look, runners could be tweaked and the plenum is way bigger than the mini-ram.
Bottom line is, there isn't a all purpose intake out there. Every motor or project has limits, be it money or power goals. Pick the intake to suite what goals YOU have. High rpm tq and HP isnt for everyone, its dang pricey!
Car: 94 camaro z28
Engine: lt1
Transmission: 4l60e
Man if I had one of those short rams I wouldn't have a problem ripping my carb right off! It just looks so perfect for our thirdgens.
Engine: TT TPI/LT-5
Got access Jim McFarlands personal e-mail......any specific questions anyone has?
I am going to cover
1)What project was the intake set for
2)What were HP/TRQ goals and were they achieved
3)Why was is scrapped?
4)RPM range?
5)CFMs....what was his impression of the end result?
6)Ask about the epoxy intake..
7)What is the purpose of the holes drilled in the valley connected to the intake port
I am going to cover
4)RPM range?
