Alternative Port EFI Intakes This board is for tech discussions and questions about aftermarket port EFI such as the HSR, MR, SR, BBK, FIRST, etc.
SuperRam/406/RollerCams?????
Old Oct 25, 2009 | 10:58 AM
TPI-Formula350-'s Avatar
Car: 89 Formula 350
Engine: Forged 385 H/C/I
Transmission: 700R4-4300 Stall-lockup
Axle/Gears: BW 9 Bolt 3:70
I'm thinking of pulling my comp XE284(240/246 .507 .510) Flat tappet cam from my 406. I think its power band doesn't match that of the SuperRam I have on the motor. The XE284 makes power from 2300-6500, but the SuperRam is done by around 5400RPMs..So I'm looking to go with a roller cam. I'm hearing good things about the TPIS ZZX cam. I have also heard good things about the LPE219 but think it would be to small for the 406. So let me know what you guys are running in you SuperRam big cubic inch small blocks?..I'm attaching a dyno sheet showing how my XE284 Cam never got to make power over 5400. So I'm looking for this roller cam to make its max power below 5500.
Old Oct 25, 2009 | 04:31 PM
radical82's Avatar
Car: '82 Camaro
Engine: 383
Transmission: TKO 5 speed
Axle/Gears: 31 spline 9" with 4.56:1
Re: SuperRam/406/RollerCams?????
In the past, when I couldn't find THE camshaft for an engine combination I called the tech guys at Comp Cams (with one of their cam sheets fully filled out) and had them build me a custom grind.... It's not all that much more and my experience has always been to end up with a cam that is absolutely correct for my car.... A custom grind does come out a lot cheaper then 2 or 3 attempts to buy the correct off the shelf grind......
Old Oct 25, 2009 | 08:39 PM
ericjon262's Avatar
Car: 85 2M6, 87 'Bird 88 'burb
Engine: LX9, LG4, L05
Transmission: F23, 700r4, 700R4
Axle/Gears: 3.63, 2.73, 4.10
espcially, IIRC comps cams are priced based on the cost of the cam core, so whether the cam is off the shelf or custom, it will cost the same as long as the core is the same material. (billet, cast, ect.)
-Eric
Old Oct 28, 2009 | 12:42 PM
HiTech5's Avatar
Car: 1986 Pontiac TA
Engine: 383
Axle/Gears: 3.70
You will want a cam with good lift while keeping the duration on the mild side. This will help you in making midrange. I like the aggressive ramp of the XFI lobes but do not care for the 113lsa that the off shelf are ground with.
PM me and I'll send you a grind.
Old Oct 28, 2009 | 01:16 PM
Car: 89 Formula 350
I spoke to Comp Cam tech yesterday and the said I'd want to go with the
Comp 280 XFI HR13
230/236
.540 .537 .576/.570 with the 1:6 Roller Rockers i'm using
part # 12-467-8
Old Oct 28, 2009 | 09:28 PM
VincentZ28's Avatar
Car: 1990 G92 IROC Z Miniram
Engine: 388cu 6.4 Liters
Transmission: G-Force T5
Axle/Gears: 3.73 Gears
You never went back to the Superram Modification thread. 82FirebirdTA made 403rwhp and 439rwtq with a 280XFI in his 406.
https://www.thirdgen.org/forums/post...57-post50.html
Old Oct 28, 2009 | 09:57 PM
Car: 89 Formula 350
I'm SOLD on the 280 XFI after seeing that!
Old Oct 28, 2009 | 10:30 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
good grind for that motor.. springs to match the cam and your set
Old Oct 28, 2009 | 11:04 PM
Car: 89 Formula 350
yeah..spoke to Comp today and I'm just going to change mine out to the Behive 26986-16 springs they suggested.
Old Oct 29, 2009 | 02:31 AM
articwhiteZ's Avatar
Engine: Aluminum 615BBC
Axle/Gears: 4.11/4.30/4.56
if this is a mech roller.. why not try Lingenfelters cam from Comp cams
it's for the supper ram intake w/1000cfm tb and 30lb hr injtrs
part #12-000-8
cs276-2-280-2R112
lash hot intake .20 ex .22 (even with this lash it's )
232/236 @.50 563/586 lift with a 1.6 rocker. this is fantastic for a 11.0 eng pulls hard to 5900 to 6000 pulls gobs of vac. also..
and Remember you can take the lash down to .10/.12 if ya like..
for a bit more lift.. and what not..
Old Oct 29, 2009 | 04:50 PM
grumpygreaseape's Avatar
Car: 85 iroc,96 z28,96 Ram 2500,69RR
Engine: 383 with AFR heads.
Transmission: richmond 5 speed
Axle/Gears: 1991 w/1LE.auburn pro series.2.73's
im running an lpe219 with 1.6 rockers. it should be bigger for a 406.
Old Oct 29, 2009 | 05:33 PM
yep....with all them cubes
