Alternative Port EFI Intakes This board is for tech discussions and questions about aftermarket port EFI such as the HSR, MR, SR, BBK, FIRST, etc.
timing issue???
Old Nov 7, 2009 | 02:14 PM
formula_novice's Avatar
Car: 1989 Firebird Formula
Engine: 383 Stealth Ram
Axle/Gears: 3.73 9 bolt Posi
timing issue???
Hi Guys,
I'm having an issue with my setup. TPIS burned a custom chip for me and the timing is suppose to be at 6* and fuel pressure at 43psi. However, when I set the timing at anything less than 10*, I get a pinging/pop noise around #3 when I step on the gas good at idle.
I'm happy it's finally idling better but now I'm not getting good throttle response and I'm assuming it is cause the timing isn't the 6* the ecu is programmed to?
FYI - I have the fuel pressure at about 44psi (idle) right now.
Any advice would be greatly appreciated!
Thanks!
Frozer!!!
Jan 19, 2024 04:55 PM
specialized
Jun 18, 2022 09:26 AM
theshackle
Sep 17, 2020 08:26 AM
djmarch
Aug 9, 2015 05:27 PM
86Base
Aug 8, 2015 01:34 PM
