Injector sizing and where to buy?
Car: 1987 IROC-Z
Engine: 383ci SBC
So I read the post on injector sizes which is stickied at the top, and came out with two numbers, and I'm curious which is right, and what injectors would work. First a little background:
My engine is a 385 stroker, HSR intake, AFR 195 heads, compresison of around 10.5:1.
The first of the two numbers I've gotten is derived from HP * .50 / 8. I'm expecting 500-550HP at the crank at the max, so that works out to 34.37, so rounding up I'd get #36 injectors.
What worries me, is that there is another post, in which someone says to use this equasion:
injector flow = [(engine Hp)] x BSFC / 6.4
Which works out to 42.96. That's a rather large difference between 34.37 and 42.96.... So which should I go for? Would overkill be a bad thing, just running the injectors at a shorter duty cycle shouldn't hurt them.
Also, I can't find information on what type of connector and specific part numbers of injectors that will work, I keep hearing about Ford and Bosch injectors... but there are quite a few with different connectors and heights. Any information would be greatly appriciated.
Edit: Nevermind found my answer.
Car: '87 IROCZ
Engine: 395 ZZ4
Transmission: ProBuilt 700R4
Axle/Gears: 9 bolt 3.70s
Re: Injector sizing and where to buy?
For the benefit of others who might be wondering the same thing:
The two equations for fuel injector sizing are really the same equation! BSFC = 0.50 for typical SBCs and the 6.4 = 8 injectors at 80% duty cycle (DC). The equation in full is:
injector size = [(eng HP) * BSFC] / [(# of injectors)*DC]
for example, if you expect to make 500 engine Hp, we get: 39#/hr injectors.
Now you could buy 36#/hr injectors (rated at 45psi) and run them at 54psi with an AFPR.
hp at the flywheel: 500hp
BSFC: 0.5
max duty cycle 80%
43.5psi
39lb or 40lb injector
If you are going to be closer to 550hp
you will need a 42lb injector
Car: 00 SSEi / 94 C4
Engine: 231 / 383
Transmission: 4T65E / ZF 6sp
Axle/Gears: 2.93 / Dana 44 3:45
if you have the 87 TPI setup you have EV1 style connectors
Delphi is the manufacture all others re-labl & re-sell Delphi injectors
the HP to CC or pound info is correct
Engine: 231 / 383
PS
always choose larger then what you need (like a battery)
you can set the flow in your programing to the correct # and adjust your fuel regulator accordingly it is much better not to go above 80% duty cycle and over working your injectors
Car: 91 B4C "police special service"
Engine: L98 494hp
Transmission: tko-600 on order
Axle/Gears: 3.23 true trac
here is a really good calculator that I use. BFSC from my understanding can be between .4 and .5 on NA motors. I never got a straight answer from that, depends on whom you talk to....but this site even has a chart, move your mouse over chart to read specific numbers.
http://www.gtsparkplugs.com/InjectorSizeCalc.html
oh, and for the duty cycle percent... use decimal style. like 80% is 0.80. (that confuses me every time for some reason, lol)
Engine: 231 / 383
The link you sent on injector sizing is perfect..
you have to decide if you current car up-grade is your final
if your engine is rated @400 HP
it is wise to plan ahead so choose 500HP
it is wise to select 0.50lbs BFSC
it is wise to stay under 80% injector duty cycle
your injectors will easily accomplish their job if you select above your calculation within reason
you can adjust your fuel pressure and your ECU injector rate flow
If i were you I would read all the horror stories.. I found many import & domestic engines trying to save money buying Venom injectors
Delphi is the manufacture.. aftermarket performance like MSD, holley purchase from Delphi
Car: 1987 IROC-Z
Engine: 383ci SBC
I called fuel injector connection and told them exactly what I had/how much power I was expecting, and they sold me a set of injectors. I don't actually recall what size they were, but in a day or two when they get here I'll post what they are :P.
I do know they're bosch ford injectors.. that's all I can recall though.
Car: 1987 IROC-Z
Engine: 383ci SBC
Alright my injectors arrived. They are ford red top 30lb injectors. Jon at fuel injector connection is the one who specced them out for me. I told him exactly what I had and how much hp I thought I was going to make. This does seem a bit low after reading the posts here... but fic comes highly reccomended from this forum so ill trust he knows what he is talking about.
Car: 1987 IROC-Z
Engine: 383ci SBC
Engine: 231 / 383
you should absolutely return them
If you really have 500 HP
you will stress 30# injectors way over 80%
you cant get every pound rating out there so you knew you need around 36 - 39 #
so get 40# injectors the moral of the story is it is safe to go over you can use a AFPR
or cut the # rate back in your prom
unlike using a carb that is to big
just like a battery if you only need 300CCA to start your car
and you buy a 900CCA battery the battery will easily and effectively accomplish it's job
PS you will need to upgrade your fuel lines to 1/2 and I hope you have a real fuel pump
I fried a brand new projection pump with 1 full throttle run
Ok, for the third time....if you are going to run approx 400hp then a 30lb injector will be fine.
If you are looking to run between 500 and 550hp then you need at least 39-42lb. Go and check out any calculator. Ours is not up and running on our website yet otherwise i would tell you to go there....but go to RC fuel injection and plug in your numbers and you will see what you will come up with. Their calculator is reliable!!!!
www.southbayfuelinjectors.com
Car: 89 Formula 350
Engine: Forged 385 H/C/I
Transmission: 700R4-4300 Stall-lockup
Axle/Gears: BW 9 Bolt 3:70
you could prob get 460 FWHP out of 30lb injectors but that would be 80%DC and the AFPR set to about 60lbs
Car: 89 iroc
Engine: l98
Transmission: tremec
http://www.golenengineservice.com/sp...402_550tk.html
Engine: Aluminum 615BBC
Axle/Gears: 4.11/4.30/4.56
Lingenfelter tuned My 92 Z28 383 475hp 490fpt With 30lbs injtrs
ran fine for 8 or 9 years.
Car: 89 iroc
Engine: l98
for a street car i would not want to use a bigger than necessary injector, unburned hydrocarbons washing down cyl walls. ending up in oil etc will prematurely ruin your engine. I laugh when I hear put in big ones and tune it down, this is such HS, the Bosch 42 doesn't work below 1.2 ms so you can't get it lean enough on idle. All you get is a loaded up idle.. All the formulas are great especially RC Eng.. as southbay said its reliable.. But, the first figure needed to calculate the right injector is HP. So if the HP is off by 20% the injector will be off also. So, the only way to know if your right, is to guess close and then scan it. When you get accurate numbers then you can get accurate injectors.
Car: 1987 IROC-Z
Engine: 383ci SBC
I dont want to get to critical here but, I don't believe that combo makes anywhere near 550. heads and cam ls1's have a tough time doing it. Stock pistons, etc.. its lower believe me. Look at TPI-Formula350s profile. He has more engine than you and runs the red Ford. If you got red tops they are 32 because ford rates them at 39.15.. At 43.5fp they are 32. You have a AFPR and your DS climbs increase the pressure.. At 58 they are like 36. When you talked to FIC did you go over your engine build? He knows what these make and would steer you to the right injector which will support your motor. This is a street car, Right? How long are you going to be at WOT anyway to worry about if the injectors jump to 90DS? Who told you you have more HP than a new ls7 anyway. Here's what you do put it on a scanner and see what the injectors run at. Do not over inject a motor. All you will do is make more problems.. Be honest and list all your mods just to make sure. I built a ton of these so I will tell you honestly what I think. Also look at this link from Golen Engines.. DOES YOUR ENGINE COMPARE TO THIS>
Here are my mods:
385 stroker engine
HSR Intake, stock throttle body
Flat top pistons with decked block
AFR 195 heads, port/plolished with, 64cc chambers
10.5:1-11.0-1 compression guesstimate by machinest.
3200rpm torque converter
I'm 99% sure this is the cam I got:
http://www.compcams.com/Cam_Specs/Ca...?csid=210&sb=0
I'll have to find the spec sheet and make sure, but it's either that one, or one level down from that.
2-1/4 dual exhaust (I know this is a limiting point here)
Anything I missed just ask.
Car: 89 Formula 350
Sounds like a nice engine, your cam is one size larger comp XFI then mine..I dont see it making 550HP. Something closer to 475 at the flywheel sounds more like it. Only way you know for sure is on a dyno.
Here are my mods:
385 stroker engine
Anything I missed just ask.[/QUOTE]
Here are my mods:
385 stroker engine
Car: 1988 IROC-Z
Engine: 427 SBC
Here are my mods:
385 stroker engine
385 stroker engine
Any sound clips?
Car: 1987 IROC-Z
Engine: 383ci SBC
You said you had one size smaller cam, how does it start and idle? I've never run a fuel injected car with a big cam before.
Unfortunately not, the car isn't running yet! I'll post one if I ever get it running though.
Car: 89 Formula 350
engine is still being built , goes on the engine stand dyno in a week or 2
Engine: 231 / 383
the HSR is Great start... I welded a 3/16 bead to mine to accept a 1206 race intake port to match my heads
if you purchase heads with a 1206 port... your HSR Intake will not cover the 1206 intake port and leave a gap
i just ran your cam timings in software engine dyno as a simple guideline
that cam makes no scene for a stroker motor and makes no power compared to a comp cam 08 306 8
your compression will not be above 10.5 with only flat tops and 64CC
I have .125 domes with 64CC and make 10.90 -11.00
your engine maybe 479HP 30# injectors are still slightly small to support your combo unless you crank up you AFPR and over work your injectors
and who wants 50 - 60 PSI on their street car
I had 30# injectors @ 46 PSI on my engine for a week it was way to lean.
and had a lean knock no where near enough fuel supply
and I program myself and use my installed 02 meter I dont need someone to guess what I have
overall your car will be alot more fun to drive.. if only the 80'S did not smog
and cut the power
enjoy
and cut the power
enjoy
Car: 89 iroc
Engine: l98
and cut the power
enjoy
and cut the power
enjoy
Engine: 231 / 383
I do not have a stock pump I do not have a useless in tank pump
I have a Aeromotive external pump And i do not need my pressure any where near 50PSI or 60PSI
my combo is flawless
is this the reason why you need to crank your 30# injectors up that high
if you re set your PSI to 35 - 40 your engine is most likely starving if you have over 475HP that would indicate you are over working your injectors
unless you have a brand that really flows 30# @ 50PSI
you only need to jump up to that pressure if your injectors are to small
or if you have a forced induction combo
I have yet to see a better performance cranking up my pressure that high on any combo I built
Car: 89 Formula 350
[QUOTE=88gta3508;4412028]I do not have a stock pump I do not have a useless in tank pump
my combo is flawless ....lmfao!
He'll be fine with 30lb injectors at 58lbs
Engine: 231 / 383
[quote=TPI-Formula350-;4412044]
YES he WILL still slightly to small injector size
LMAO what are you laughing at hm ohhhhhhhhh your combo must be making at least 900HP I did not know that was U ROCK U LOL
Car: 89 Formula 350
no I dont make 900 HP ..lol.. more like 475 FWHP... but Thanks
Engine: L98 494hp
Now here is the question that I notice no one is really mentioned. Is the numbers fly wheel horse or rear wheel horse. That would make a difference. A motor producing 500 flywheel may only make 400 rear wheel. So then the calculations for the correct injector size changes. There is no specification listed which one to base numbers off of.
I based my numbers off of my rear wheel horse, and the numbers came out to 30lbs, if I base off flywheel , I need more like 38-40lbs. Need to take that into consideration.
Car: 89 Formula 350
How do u like that 280XFI cam??, having that cam installed in my new 383
Engine: L98 494hp
yeah, I made just under 500 flywheel horse (and about 380 hp at the rear wheels).....with the 30's on mine...my tuner (since I don't tune the computer myself) suggest the 30's and I went with them...hopefully mine aren't too small either...but I think I based mine off rear wheel power. I run 45psi on the lines.. but it runs out alright, no dead spots and doesn't feel like it's running out of fuel.
LOVE LOVE the cam. Runs out great. little doggy out of the hole, but get it around 2600-3000 rpm it start pulling hard, and runs out to 6500rpm, and still pulling hard when I shift. Sounds awesome at idle, very nice lope, and is streetable for sure still.
toronto formula
Nov 10, 2015 06:17 AM
New2Chevy
Oct 4, 2015 11:27 PM
knight72
Aug 10, 2015 09:32 PM
