Alternative Port EFI Intakes This board is for tech discussions and questions about aftermarket port EFI such as the HSR, MR, SR, BBK, FIRST, etc.
MAP sensor location
Old Nov 28, 2009 | 02:29 AM
ericjon262's Avatar
Car: 85 2M6, 87 'Bird 88 'burb
Engine: LX9, LG4, L05
Transmission: F23, 700r4, 700R4
Axle/Gears: 3.63, 2.73, 4.10
MAP sensor location
does it matter where the MAP sensor gets it's vacuum supply from?
Thanks-
Eric
Old Nov 28, 2009 | 05:28 AM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: MAP sensor location
So long as it sees manifold vac it doesn't matter.
I believe some trucks came with a remote mount MAP
Old Nov 28, 2009 | 10:52 AM
ericjon262's Avatar
Thanks thats what I needed to know!
Old Nov 28, 2009 | 11:45 AM
grumpygreaseape's Avatar
Car: 85 iroc,96 z28,96 Ram 2500,69RR
Engine: 383 with AFR heads.
Transmission: richmond 5 speed
Axle/Gears: 1991 w/1LE.auburn pro series.2.73's
yes-direct dedicated vacuum line from the intake manifold to the map sensor with no tee's, y's or what have you in between.
Old Dec 14, 2009 | 01:16 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
Yep, i have map sensor with dedicated line from plenum to the map. Should work fine that way, it doesnt have to be directly attached to the manifold
Old Dec 15, 2009 | 03:16 PM
83 Crossfire TA's Avatar
huh... now you have me thinking, where did the SD TPI cars run theirs from? Either the later TPI's had more vacuum fittings or they pretty much had to have it T'ed somewhere.
Old Dec 15, 2009 | 03:31 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
LT1 cars had the sensor directly mounted to the Plenum and I thought the TPI cars were the same?
Old Dec 19, 2009 | 11:30 PM
LT1's had them mounted right behind the throttle body on top of the plenum, but they were only really there to detect emissions tampering.
TPI cars have them mounted on the firewall on the passenger side on the firewall, but I don't know how it's connected to the plenum.
Old Dec 20, 2009 | 07:46 PM
ericjon262's Avatar
Later TPI's had an extra vac barb.
Old Dec 21, 2009 | 03:54 PM
Duts87ss's Avatar
Car: 1987 Monte Carlo SS
Engine: HSR 383 AFR180/268XFI EBL
Transmission: 200-4R, Edge 2800 L/U
Axle/Gears: 7.5/3.73/PowerTrax No-Slip
I thought TPI cars had the MAP sensor mounted to the plenum.
Old Dec 24, 2009 | 09:55 PM
1bdbrd's Avatar
Car: 1991 Trans Am
Mine is bolted to the plenum but uses a special L shaped hose to pull the vacuum from the plenum.
Nick McCardle
Sep 10, 2015 08:36 PM
raymondandretti
Exterior Parts for Sale
Sep 5, 2015 05:02 PM
willyjoejr
Sep 3, 2015 09:26 AM
tonys91rs
Sep 2, 2015 07:07 PM
