HSR Fuel Rails
Car: 88 GTA + Dakota on N20
Engine: 383 4 bolt
HSR Fuel Rails
I bought a HSR setup off the forums here and my fuel rail just has a large threaded hole on the back of it. Does anybody know what size it is so i can order an adapter to make it -6 an? Also what size is the fitting going into the fpr?
Here is the stuff im ordering so far.
EAR-306006ERL 6ft -6 an earls autoflex hose "is this enough or 10ft"
991954ERL Earls Performance 14mm to -6an adapter
991955ERL Earls Performance 16mm to -6an adapter
RUS-624260 Two Russel 120 degree -6 an hose ends
SUM-800260 Fuel Gauge
HLY-26-69 1/8 in. NPT Male, 1/8 in. NPT Female 90 degree fuel gauge fitting
Engine: 383 4 bolt
Re: HSR Fuel Rails
Just looked up the Holley 534-185 fuel rail instruction manual. It doesn't say what size they are. All it says is the parts are called an inlet fitting and a regulator return fitting.
Any help would be appreciated.
Car: 1995 Formula
Engine: LT1 350
Transmission: Built 4L60e
Axle/Gears: 10 bolt, Eaton posi, 3.73's
Re: HSR Fuel Rails
I need to know this info, as well. It's probably on this forum somewhere. Just gotta search for it.
On Probation
Car: 1989 Formula,1991 z28
Engine: 400 Vortec Hsr,496bbc
Transmission: TKO600,TH400
Axle/Gears: 9"4.10, 9"3.73
Re: HSR Fuel Rails
they are 6an ORING, to male 6an...
these are also known as AN ORB fittings..
http://www.summitracing.com/search/S...?Ns=Rank%7CAsc
http://www.summitracing.com/search/S...?Ns=Rank%7cAsc these work well for the passenger side REAR where the inlet is.
there ya go guys, i just had to order all this stuff up for my HSR formula..
Engine: 383 4 bolt
Re: HSR Fuel Rails
I just got an email from holley. The factory part numbers are 9906-127 for regulator and 9906-122 for fuel rail. Since 89fbirdformula's parts seem to be 1/2 the price I think ill be going with them. Thank you 89birdformula.
On Probation
Re: HSR Fuel Rails
no problem man, glad i could help you out...i will have all of the factory fuel rail fittings from my HSR kit for sale if anyone needs/wants them...i have switched to anodized AN type fittings.
Engine: 383 4 bolt
Re: HSR Fuel Rails
I ordered this for the rail and it works great
http://www.summitracing.com/parts/EAR-985006ERL/
I ordered this for the Regulator and it doesn't want to thread in
http://www.summitracing.com/parts/FRA-499206/
It looks like the threads on the adapter are too fine to fit into the reg. I didn't try to force it because I didnt want to cross thread but I tried for quite awhile. It looks to be the right size but just wont thread. Any ideas? Did I order the wrong part?
PS. I just tried the rail fitting in the reg and it wont thread in either.
