Alternative Port EFI Intakes This board is for tech discussions and questions about aftermarket port EFI such as the HSR, MR, SR, BBK, FIRST, etc.
Question about my HSR?
Old May 30, 2010 | 02:20 PM
robbyk85's Avatar
Car: 85 iroc
Engine: 383
I thought that the stock TPI vacuum fittings would work on the HSR. What are guys using, and where can I buy? Question about my HSR?-img_3802.jpg
Old May 30, 2010 | 05:51 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: Question about my HSR?
Can get fittings from any auto supply place.
2 larger holes are 3/8" NPT ( one should be used for brake vac ) and IIRC 2 smaller are 1/8" NPT
Old May 30, 2010 | 08:24 PM
Wishmaster's87IROC's Avatar
Car: 1987 1SICIROC.....1999 TransAm
Engine: 385 HSR.....LS1
Transmission: 700R4 with Midwest 3400 2.4str...M6
Axle/Gears: SLP Zexel Posi unit 3.42's...3.73's
or you can get them at Lowes or home depot.......they may be cheaper there. Also your gonna plug 1 or 2 of them, i cant remember. You can get them at the same place.
Old May 31, 2010 | 12:05 AM
IROCThe5.7L's Avatar
Car: 1988 IROC-Z
Engine: 427 SBC
Transmission: ProBuilt 700R4
A ton of information here: https://www.thirdgen.org/forums/alte...ealth-ram.html
I used all 4 vacuum lines on the back of mine. AFPR, brake booster, IAT, and I think the last one was for the cruise control.
Old May 31, 2010 | 01:01 AM
86White_T/A305's Avatar
Car: 1987 TransAm Ttop
Engine: 2005 LQ4
Transmission: Ls1 T56
Axle/Gears: 3:54
Thats the exact same thread I used to find out what fittings I needed to run my vacuum lines today lol.I got everything hooked up except for the vacuum lines that are coming out from the hvac.I dont know how I should hook them up or if there was a check valve inbetween them.Anyone got a diagram for that?
Old May 31, 2010 | 06:55 AM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
Originally Posted by 86White_T/A305
except for the vacuum lines that are coming out from the hvac. I dont know how I should hook them up or if there was a check valve inbetween them.
Check valve on HVAC / cruise line keeps vac in system when engine vac drops
Line should run
Intake - check valve - then from valve -rear port to HVAC line / side port to vac ball T'ing off to the cruise on the way.
If you don't run the check valve, your vent position will change every time you accel because the vents will return to the default position with no/ low vac
355tpipickup
Aug 29, 2015 10:47 PM
ASE doc
Aug 25, 2015 09:14 AM
trevor1010
Aug 24, 2015 11:29 AM
355tpipickup
Aug 22, 2015 06:06 PM
redmaroz
Aug 16, 2015 11:40 PM
