Alternative Port EFI Intakes This board is for tech discussions and questions about aftermarket port EFI such as the HSR, MR, SR, BBK, FIRST, etc.
Question HSR Swap with stock Throttle Body.
Old Feb 13, 2011 | 02:27 PM
Looksthakill's Avatar
Car: 1985 Chevy Camaro Z28
Engine: 5.0 LG4
Hello,
With the original TPI setup, there was a small, U-shaped hose that went from the intake manifold into the bottom of the Throttle Body.
* Question: Do I need to run something to this for an HSR swap? I have seen other guys pics, where they have left this port on the Throttle Body open, not plugged or connected to anything.
Please share your response. THANKS GUYS!
Old Feb 13, 2011 | 04:39 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: Question HSR Swap with stock Throttle Body.
No
was for coolant to heat TB up to prevent blades from freezing up in cold weather.
Is 1st thing most delete; even with stock intakes
While you have everything apart do it properly; cut off the redundant coolant part just leaving the IAC valve housing
Old Feb 13, 2011 | 08:16 PM
Engine: 5.0 LG4
Thank you for the response Vettoz. I got the car running today. Now I need to tune and tweak.
jhawkeye
May 25, 2022 06:33 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
Fast355
Dec 2, 2016 06:33 PM
justin57
Aug 20, 2015 07:05 PM
redmaroz
Aug 16, 2015 11:40 PM
