Alternative Port EFI Intakes This board is for tech discussions and questions about aftermarket port EFI such as the HSR, MR, SR, BBK, FIRST, etc.
Coil location question.
Old Mar 30, 2011 | 04:09 PM
87IROCZCamro's Avatar
Car: Chevrolet Camaro IROC-Z,96 Vette
Engine: 350 5.7 Liter
Transmission: 700r
Can someone help with where the coil with go on the stealth intake. I do not know where to put it. Thanks
Old Mar 31, 2011 | 07:15 AM
Burnout91's Avatar
Car: '91 Z28 L98 G92
Engine: Modded L98
Transmission: Modded 700R4
Axle/Gears: Modded 10-Bolt
Re: Coil location question.
I mounted the coil in the stock location, AFTER trimming-off the lug located between the right-rear manifold-to-head bolt holes on the manifold base.
Old Mar 31, 2011 | 12:08 PM
Transmission: 700r
For some reason mine does not have the right spacings. Can I mount it on the firewall?
Old Mar 31, 2011 | 12:51 PM
Burnout91's Avatar
Engine: Modded L98
You could; if you search around the forums I'm pretty sure you will find a picture of a firewall-mounted coil.
Nick McCardle
Sep 10, 2015 08:36 PM
Jlanz55
Sep 6, 2015 02:35 PM
Ian Irvine
Sep 4, 2015 08:08 AM
tonys91rs
Sep 2, 2015 07:07 PM
