Alternative Port EFI Intakes This board is for tech discussions and questions about aftermarket port EFI such as the HSR, MR, SR, BBK, FIRST, etc.
SUPER CHARGED HSR DISCHARGE TUBE QUEST
Old May 18, 2011 | 11:13 PM
FEDBYVORTECH's Avatar
Hello I have a Vortech super charger. It is a 88 tpi set up. I pulled my TPI unit and installed HSR. The HSR sits higher. Is there a bolt on discharge tube? I am not running intercooler at this time. thanks
Old May 28, 2011 | 08:15 AM
Re: SUPER CHARGED HSR DISCHARGE TUBE QUEST
Old Jul 13, 2011 | 06:32 PM
Anyone have a picture of there super charged HSR with intake tube?
Old Jul 20, 2011 | 06:50 AM
tom86iroc's Avatar
Car: 1986 iroc
Engine: alum. head 350 supercharged
Transmission: 6speed
Axle/Gears: ford 9in 3.90 35 spline moser axles
could try this for now till you get your intercooler in http://www.trickflow.com/egnsearch.a...5&autoview=sku
Old Jul 21, 2011 | 06:40 AM
Six_Shooter's Avatar
Transmission: 5-speed/T-5
Could also clock the housing a bit and use about a 30* elbow silicone coupler.
Old Jul 21, 2011 | 07:27 AM
anesthes's Avatar
TGO Supporter/Moderator
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Might hit the hood.
I'd just use a rubber or metal 90* bend meant for a 3" pipe to 4" oval (TPI/LT1 throttle body) and run a tube right into the blower.
I might have some pictures somewhere I can post. I ran that blower with a lot of different intake combos.
Actually, I also ran a miniram on my corvette with a blower and I think I used the same thing I'm suggesting on that car before sticking a singleplane on it.
-- Joe
Old Jul 21, 2011 | 04:39 PM
Ronny's Avatar
looks like it might align if you extend/replace the coupler from TB to the whatever it is called with a longer one? Is that coupler you are using available in a longer lenght then cut to size?
gixxer92
May 18, 2017 11:20 AM
SS-EXPRESS
Sep 28, 2015 09:14 AM
RS Reaper
Sep 27, 2015 07:04 PM
Damon
Sep 26, 2015 04:29 PM
Dragonsys
Sep 25, 2015 03:51 PM
