Alternative Port EFI Intakes This board is for tech discussions and questions about aftermarket port EFI such as the HSR, MR, SR, BBK, FIRST, etc.
MiniRam install?
Old Jun 18, 2011 | 12:17 AM
play4keeps's Avatar
Car: 1991 Z28 Vert
Engine: 305ci
MiniRam install?
Just got my hads on a MiniRam intake, planning on installing it this weekend. anyone know where I can get my hands on som install instructions? pdf. or anything. any tips? anything that would help? thanks!
Old Jun 18, 2011 | 07:28 AM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
Re: MiniRam install?
Call TPIS
http://tpis.com/
Old Jun 19, 2011 | 05:59 PM
play4keeps's Avatar
Car: 1991 Z28 Vert
Engine: 305ci
ok, got the miniram installed, The direct fit fuel lines supplyed by TPIS dont seem to fit right... and one of the fittings will not even fit on the fuel inlet line! kind of P*ssed being that I just paid the extra $100 bucks for them and they dont even fit right. How are your lines routed and has anyone else had this issue...
Old Jun 19, 2011 | 09:26 PM
trocustoms's Avatar
Car: 1988 GTA Black on Black Hardtop
Engine: 383 miniram/ Ebl
Transmission: 700r4/Performabuilt/3000 Stall
Axle/Gears: 9 bolt / 3.27
Which lines did you purchase? I got the braided flexible lines from tpis and they worked perfect. Did you get hard lines?
Old Jun 19, 2011 | 10:24 PM
TTOP350's Avatar
Definition(sp) of peformance parts is---- It doesn't fit !
if you have the hard lines, yes you will have to tweak them a bit..
If it was easy.... Everyone would do it !!!
Glad ya got it installed you'll dig it.
Old Jun 19, 2011 | 11:29 PM
play4keeps's Avatar
Car: 1991 Z28 Vert
Engine: 305ci
I got the flexible lines. three of the fittings have a 120 angle and one has about a 60 degree angle, all four ends have the same size fittings. not sure where they actually go... they didn't come with instructions.. maybe I'm doing it wrong. witch one is the is suppose to be the return? I'm attempting to rout em off to the driver side and affix them to the fittings right next to the wheel well (is his where there suppose to go?) but the pressure fitting on the car is larger then the return, iv got all of them on but that one its bukoo! haha, HELP please... Thanks guys!
Old Jun 20, 2011 | 06:44 AM
trocustoms's Avatar
Tried to post up pics last night but failed. I found the pic you need. Do a search in alternative port intakes.
Type in miniram pics and go to the thread titled minirm install pics needed. Posted by justin 89 formy. The second post has the pic you need.
Good luck
Old Jun 20, 2011 | 07:28 AM
play4keeps's Avatar
Car: 1991 Z28 Vert
Engine: 305ci
Good luck
Thanks! ill take a look!
Old Jun 20, 2011 | 09:38 AM
play4keeps's Avatar
Car: 1991 Z28 Vert
Engine: 305ci
ok... here is my problem... have the lines routed but the line wont screw onto the fitting, it is larger the the other... did i get the wrong fitting on my line or im I in the wrong place all together?
Old Jun 20, 2011 | 10:12 AM
Twin_Turbo's Avatar
Because you need these:
http://www.summitracing.com/parts/EAR-9894DBHERL/
http://www.summitracing.com/parts/EAR-9894DBJERL/
They should have come with the miniram, the tpis ones are identical apart from the fact that they are not anodized blue, they're bare aluminum.
Old Jun 20, 2011 | 10:15 AM
trocustoms's Avatar
Your in the correct spot.
You should have 2 adapters that thread onto the hard lines then onto your braided lines. Do you have the adapters?
Old Jun 20, 2011 | 10:17 AM
play4keeps's Avatar
Car: 1991 Z28 Vert
Engine: 305ci
thanks, they did not come with, Im going to call TPIS right now. so much brain damage and now im without my car... it took over a week and a half for them to ship me the stuff originaly.... thanks again
Old Jun 20, 2011 | 10:33 AM
play4keeps's Avatar
Car: 1991 Z28 Vert
Engine: 305ci
Just talked to Jim at TPIS, He has them on the way. thanks erre buddy!!
Old Jun 20, 2011 | 11:35 AM
TTOP350's Avatar
O boy you may have to put a new AN fitting on the part you screwed to the factory hard line! If the seat or threads got messed up.. Can't believe you got a metric saginaw "O"ring fitting screwed into a AN cone and seat fitting !!
Def check those AN fitting threads and the seat! AN fittings should screw down with finger pressure until the end. the seat cannot have any knicks at all or it'll leak/seap.. not good by the headers or manifolds..
Old Jun 20, 2011 | 11:43 AM
play4keeps's Avatar
Car: 1991 Z28 Vert
Engine: 305ci
Yeah... They said they sent me every thing I was going to need. guess not, I didnt tighten the fitting just yet cuz I want sure if it was in the proper place, I hope its not messed up too. I may just replace it...
Old Jun 20, 2011 | 01:48 PM
TTOP350's Avatar
Ok, good deal! I just didnt want to hear about losing another 3rdgen due 2 fire....
Old Jun 20, 2011 | 02:28 PM
Twin_Turbo's Avatar
You can simply use a unf tap to recut the threads carefully, as long as the taper seat isn't messed up and the threads are not completely stripped. -6AN is a 9/16-18 thread
Old Jun 23, 2011 | 10:52 PM
play4keeps's Avatar
Car: 1991 Z28 Vert
Engine: 305ci
finally got her all back together right now... now she wont start. hahaha ran out of light...
Old Jun 25, 2011 | 12:12 AM
play4keeps's Avatar
Car: 1991 Z28 Vert
Engine: 305ci
ok, still cant get her to start, Iv narrowed it down to the fuel pressure regulator. dont now anything about these. tryed turning the screw both ways, still cant get it to flow through? I have the vacume line hooked up too.... any ideas?
Old Jun 25, 2011 | 02:09 AM
Twin_Turbo's Avatar
Feed & return hooked up properly or mixed up? The system should bleed itself and start quickly after install.
Old Jun 25, 2011 | 11:12 AM
play4keeps's Avatar
Car: 1991 Z28 Vert
Engine: 305ci
Yeah, the feed is hooked up to the regulator but that's as far as the fuel gose, coult the regulator be bad? Hopfully I'm doin it wrong
Old Jun 25, 2011 | 11:37 AM
Twin_Turbo's Avatar
The feed hooks to the fuel line, the return to the regulator
Old Jun 25, 2011 | 11:46 AM
play4keeps's Avatar
Car: 1991 Z28 Vert
Engine: 305ci
A lil bit of the right info gose a loin way, thanks again!
Old Jun 25, 2011 | 01:26 PM
play4keeps's Avatar
Car: 1991 Z28 Vert
Engine: 305ci
She starts but won't stay running, what fuel pressure should I be running?
Old Jun 25, 2011 | 01:40 PM
Twin_Turbo's Avatar
around 36 w/ reference line hooked up, with no ref line it should be around 42
did you set minimum air & adjust TPS?
Old Jun 25, 2011 | 02:40 PM
TTOP350's Avatar
I recomend setting your fuel psi 2 48-50 with vac line disconected..
Old Jun 25, 2011 | 04:32 PM
play4keeps's Avatar
Car: 1991 Z28 Vert
Engine: 305ci
The vac line is hooked up, running great at 40, but stalls if I put it in drive or reverse. Getting closer! Iv connected all vac lines...
Old Jun 25, 2011 | 06:15 PM
play4keeps's Avatar
Car: 1991 Z28 Vert
Engine: 305ci
Here's a video of hoeme its all hooked up, not sure where all the vac lines are supposed to go or what there for, all input will help, she still stalls when I drop it into gear unless I bring it up to 1500 RPM while I'm doing it.
http://www.youtube.com/watch?v=-Y5qn...e_gdata_player
Old Jun 25, 2011 | 07:43 PM
Twin_Turbo's Avatar
For one, do not hook the map to a shared vac connection, t-ed like you have. Give it a dedicated line.
Secondly, what did you set the timing at? What's the idle rpm in P/N and does it drop a lot in gear?
Old Jun 26, 2011 | 04:49 PM
play4keeps's Avatar
Car: 1991 Z28 Vert
Engine: 305ci
IT'S ALIVE!!!!! Thanks guys, it was the timing, took her for a drive today! Still doggin a lil nothing a few tweeks wont fix. I'm just glad to he behind the wheel again.
Old Jun 29, 2011 | 10:41 PM
VincentZ28's Avatar
Car: 1990 G92 IROC Z Miniram
Engine: 388cu 6.4 Liters
Transmission: G-Force T5
Axle/Gears: 3.73 Gears
I see why it stalls. The vac lines to the throttle are not hooked up. duh!
Old Jun 30, 2011 | 12:14 AM
play4keeps's Avatar
Car: 1991 Z28 Vert
Engine: 305ci
What vac lines am I missing? a vac line to the throttle body?
Old Jun 30, 2011 | 06:15 AM
VincentZ28's Avatar
There are 3. The top one goes to the passenger side valve cover. The next one goes to the canister(smog) near the left head light. The small one under the throttle body goes to the egr solenoid.
Old Jun 30, 2011 | 07:10 AM
play4keeps's Avatar
Car: 1991 Z28 Vert
Engine: 305ci
Wow, I have no idea what lines go where.. egr valve isn't there anymore, the new miniram didn't have one.
Vintageracer
Jan 10, 2020 05:33 PM
redmaroz
Apr 25, 2017 07:14 AM
dennisbernal91z
Fabrication
29
Mar 2, 2017 12:04 PM
LT1Formula
20
Nov 14, 2015 12:02 AM
gixxer92
Sep 1, 2015 04:32 PM
