Alternative Port EFI Intakes This board is for tech discussions and questions about aftermarket port EFI such as the HSR, MR, SR, BBK, FIRST, etc.
Miniram install question
Old Jul 10, 2011 | 08:32 AM
Tony89GTA's Avatar
Car: 89 GTA
Engine: 5.7L Supercharged
Axle/Gears: Moser 9" 3.70
So at the final stages of getting everything in order before I swap out the intake hopefully this week, but I got my intake used so not sure what to do with the IAT sensor. I got the wire that comes with the kit and I imagine it takes the 93+ sensor from looking at the connector but how do I go about hooking this up? Is there a bung that comes with the sensor that I can install in the intake track or something, maybe I can find something at the wreckers?
If any of you guys have pic's or insight on this that would be great
Old Jul 10, 2011 | 09:12 AM
Re: Miniram install question
It works ALOT better to put the sensor out in the air duct somewhere, before the TB.
Old Jul 15, 2011 | 07:39 PM
Beater79TA's Avatar
In the photo you see a red silicone 90* bend. The IAT sensor is inserted into that piece of silicone. Take your sensor and go to a hardware store to locate the correct size nut to put on it to hold it in place and then drill a hole in the intake duct to insert it in. Periodically check it to make sure it is still tight.
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
ASE doc
Aug 25, 2015 09:14 AM
redmaroz
Aug 16, 2015 11:40 PM
