Alternative Port EFI Intakes This board is for tech discussions and questions about aftermarket port EFI such as the HSR, MR, SR, BBK, FIRST, etc.
hsr avenger?
Old Sep 9, 2011 | 11:01 PM
skylineR32's Avatar
Car: 89 Formula 350
Engine: 406 HSR
hsr avenger?
Im new to fuel injection, i just wanted to know if there was an advantage to using the holley avenger set up versus just modifying the stock set up when using the hsr intake? does anyone on here use the avenger system? i was told it was more programable.
any info would be greatly appreciated.
thanks
Old Sep 10, 2011 | 03:02 AM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: hsr avenger?
Originally Posted by skylineR32
wanted to know if there was an advantage to using the holley avenger set up vs just modifying the stock set up when using the hsr intake?
Why buy a new computer and harness ( $$$ ) if you already have one?.
Plenty running a HSR with stock ECM (re-tuned )
Once you have correct tune for the HSR in your stock ECM you will never need to change it so ease of programming goes out the window as a buying factor ;unless you are going to be constantly changing things in the engine.
Plenty of online programmers experienced in HSR tunes
86z89iroc
Oct 5, 2015 01:04 PM
86CamaroDan
Sep 29, 2015 10:08 PM
mike22115
Sep 28, 2015 04:49 AM
BBSDesigns
Sep 22, 2015 03:08 PM
makaveli09
Sep 15, 2015 10:43 AM
