Alternative Port EFI Intakes This board is for tech discussions and questions about aftermarket port EFI such as the HSR, MR, SR, BBK, FIRST, etc.
First intake question
Old Dec 16, 2011 | 11:22 PM
89 350's Avatar
Car: 1989 formula
Engine: 350 l98
Transmission: 700R-4
Axle/Gears: 327
Is the First intake worth putting on a stock l98 and if so what type of gains can expexct thanks guys looking into this system just want to get some info before i put down 1200 or so dollars
Old Dec 17, 2011 | 03:12 AM
weaselbeak's Avatar
Re: First intake question
Everything else stock I would say no. no sense bringing all that air in if you can't get it out.
Old Dec 17, 2011 | 08:55 PM
89 350's Avatar
Car: 1989 formula
Engine: 350 l98
Axle/Gears: 327
ok thanks for the response
Old Dec 18, 2011 | 02:03 PM
Tony89GTA's Avatar
Car: 89 GTA
Engine: 5.7L Supercharged
Axle/Gears: Moser 9" 3.70
You might gain around 15-20 hp though a full exhaust would probably help more, don't forget to do something with the intake track to cause the firebird ones are crap.
Old Dec 23, 2011 | 02:07 PM
BadSS's Avatar
https://www.thirdgen.org/forums/post...43-post41.html
The link above is from another FIRST post that a member entered HP point from an old article from May 1989 Car Craft.
The baseline was a totally stock TPI unit with a stock chip set at 6 degrees
The AS&M set up is a hand ported stock base with their AS&M runners and ported plenum using a stock chip at 6 degrees
SLP brought a prototype intake called the ShortRam that never made it to production. It looks VERY much like the Holley StealthRam and they brought a custom chip to use for testing.
TPiS used the "Big Mouth" intake, their Semi-Siamesed runners, an air foil, and a modified MAF sensor, stock chip,,, set at 6 degrees.
Air Sensors, FIRST used it's single mono blade throttle body,,, which should flow around 800 cfm,, it's own fueling electronics, and 4" MAF sensor with a mechanical advanced distributor set at 6 degrees.
This was basically a stock L98 with the old Edelbrock 1.5" / 1.625" headers running through an F-body dual cat exhaust system. I doubt very seriously any of the systems were nuts on tuned but I doubt they were way off either. The FIRST unit might have had an advantage of user tuning,,,, that might be good,,, it might be bad. It had an advantage with a larger MAF sensor and throttle body than the rest,,, but it's not like this stock engine actually needed it. So,, I think the results would have been within a couple HP using the stock TPI electronics and ported MAF.
So, it I’d guess swapping the stock intake to the FIRST using the same electronics on a stock engine, assuming it already has a decent exhaust system to begin with would yield about 20 HP in the cell and about 16RWHP with an automatic.
Old Dec 23, 2011 | 09:20 PM
89 350's Avatar
Car: 1989 formula
Engine: 350 l98
Axle/Gears: 327
great thanks don't really think that is the way to go them
Old Dec 27, 2011 | 12:34 PM
88fastgta's Avatar
Car: 1988 Flame Red Trans am GTA
Engine: Forged 355 4 Bolt, FIRST TPI
Axle/Gears: ls1 torsen 3.42 gear
well i switched to a modded tpi to a first injection tpi setup and i felt a big difference in mid range and upper rpms but my engine is far from stock...
id say for a stock engine its not worth the swap considering you need to make up your own fuel lines and make some of your factory wires abit longer...
Frozer!!!
Jan 19, 2024 04:55 PM
theurge
Aug 21, 2015 12:46 PM
redmaroz
Aug 16, 2015 11:40 PM
kyle5647
Aug 15, 2015 11:56 PM
