Changing Set-Ups, Need Cam Advice
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Re: Changing Set-Ups, Need Cam Advice
Car: '89 IROC-Z
Engine: LSx
Weird that its not branded Holley all over the place. What do you use for your throttle cable set up?
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Car: '89 IROC-Z
Engine: LSx
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
This is how it looks in the car. I will go out to the garage in a bit and snap a closeup of the TB.
Actually here is one:
http://media.photobucket.com/image/h.../holley001.jpg
-- Joe
Car: '89 IROC-Z
Engine: LSx
Is that what your talking about?
Also the other pic shows your cable bracket, whats the deal with that, I didnt even think of that
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
As far as the cable bracket goes, I have the holley one that came with the TB, however I don't see why you couldn't just get an aftermarket one and adjust it back and/or up as needed.
You'll need a throttle cable for a carbureted thirdgen, of course. Don't be tempted to try and use a TPI cable, it will be too long and the curve required between the bracket and firewall gromet will make it bind and split eventually.
-- Joe
Car: '89 IROC-Z
Engine: LSx
So I can find the stud no problem but I have no idea what will work for a bracket. I might call Holley and see what they say.
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Car: '89 IROC-Z
Engine: LSx
I saw that but I guess the whole "Transmission Bracket" threw me off. That mounts with the fuel rail doesnt it?
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
-- Joe
Car: '89 IROC-Z
Engine: LSx
Ahhh yes I see, thanks for all the help Joe. I cant wait to get this thing in, I'm so glad I went on ebay that day
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Car: '89 IROC-Z
Engine: LSx
Very true, this must be a very early model I'm guessing. Maybe before holley got to cutler?
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
http://www.greatlakes4x4.com/showthread.php?t=211795
Hey, if you get a chance, could you measure the height of your HSR from the china wall (or table if it's on one) to the top? I can't seem to find that measurement anywhere.
-- Joe
Car: '89 IROC-Z
Engine: LSx
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Car: '89 IROC-Z
Engine: LSx
So whats everyone suggest for rocker arms? I was running COMP ultra golds on my last motor. They seem to be there top of the line, and theyve since revised them and the price.
I noticed Jegs has what looks to be a renamed version of the older style of COMPs http://www.jegs.com/i/JEGS+Performan...20165/10002/-1
Then theres these which they say they can take over 350lbs of spring pressure but I wonder how much more that is - http://www.summitracing.com/parts/CCA-1002-16/
And of course for an extra $10 over the above thers the new ARC golds - http://www.compperformancegroupstore...Code=SBCGOLDV8
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
-- Joe
Car: '89 IROC-Z
Engine: LSx
That and if I do end up needing the 8019's on the AFR's the added pressure that will be there.
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Which ones? I mainly ask because when I was putting my last motor together and I was researching rockers I saw alot of horror stories with broken trulions and rollers, even on brands like scorpian thats why I dished out the extra on the comps.
I might not be willing to put aluminum rockers on a motor with a solid cam though. Anything with lash might be a compounding factor for a broken lifter.
-- Joe
Car: '89 IROC-Z
Engine: LSx
Does anyone know if the TB hats on TBI motors fit over these tb's?
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Yes. Same diameter. In fact, I had a problem with an air cleaner and had to use a 5.7 TBI (l05) spacer to raise the air cleaner because the linkage smacked the bottom of it at half throttle.
For your naturally aspirated setup, I'd pick up a cheap spectre cold air setup for a carb, and run a K&N in the fender. Unless you have a cowl hood.
Did you email Tony Mamo for cam advice?
-- Joe
-- Joe
Car: '89 IROC-Z
Engine: LSx
Yes I'm planning on picking up a 2 or 3 inch cowl hood as one of the last buys before the car goes on the road and the only carb hats I could find were buy spectre and the extreme velocity ones.
I figured if a TBI one works I could probably get it for 10-15 bucks at the jy and run a CAI off that and yes I just picked up a intake tube off a 360 Dodge truck that will fit perfectly through the fender well. Only problem is its only 3.2" inside diameter and I'd like to run a 4" set up, might just do it 4th gen style.
I poked around AFR's site the other day and didnt see his email listed anywhere and I've been so busy getting the floorpan done I havent gotten around to looking again.
Hello, Michael
Aug 20, 2015 03:19 PM
