3.5" or 4" CAI for an HSR
Car: 87 monte aerocoupe
Engine: 383 HSR w/ novi 2000
Transmission: Built 4l80e circle d converter
Axle/Gears: Currie 9" 3.89 gears
I finished swapping over to an HSR and was curious on what size intake to run, 3.5 or 4. I will be using siliconeintakes.com to build it. HP level is around 480-500 flywheel. I did a search but could not find a lot of info.
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
Re: 3.5" or 4" CAI for an HSR
On my motor I ran a 3.5" setup vs stock TPI camaro intake but with gutted filter bottoms + ram air ducting to get a ram air effect at speed.
Track results appeared to be same exact times...no real gain in power either way. This was with a 3.5" maf too so the entire system was 3.5" vs the TPI camaro stuff.
I'd just build a 3.5" since it should be abit cheaper and have plenty of air flow to support 500hp.
I thought the tpi intake was more restrictive than that. I have one laying around somewhere complete, maybe I will do that. Otherwise, the 3.5 was more likely the way I would go.
Car: 89 Iroc-z
Transmission: TH400
People claim it is a restriction, but on my 11.4's motor, it didnt make any difference.
That good to know, I may just go that route instead. Thanks Orr
Were you also using the stock lid with probable kn filters?
Car: 89 Iroc-z
Transmission: TH400
Yeah it was stock lid, stock MAF but with screens removed (left the fins), and K&N filters with the bottoms of the lower box cut out with cheap dryer ducting run from bottom of boxes to fog lights.
crude/cheap but effective enough
green is where I cut. See theres the factory scoop plastic behind the fog lights that I wrapped the ducting around to help force air to flow upwards to filter boxes
86CamaroDan
Sep 29, 2015 10:08 PM
