Alternative Port EFI Intakes This board is for tech discussions and questions about aftermarket port EFI such as the HSR, MR, SR, BBK, FIRST, etc.
MSD-8366 or MSD-5591 for HSR?
Old Feb 13, 2012 | 08:56 PM
Fronzizzle's Avatar
Car: 1985 IROC-Z
Engine: 383
After tons of searching and question-asking, I think I've narrowed my distributor choices down to the MSD-8366 or the MSD-5591. Other than the 8366 being billet aluminum (as opposed to cast), not sure why it would be $115 more. Both are computer controlled. Hoping someone can shed some light on the differences and if it's worth it to go to the MSD-8366. Thanks.
PS - This is going in a 1985 Camaro 383 Stroker with a HSR and 90 - 92 MAP ECM and wiring harness setup.
Old Feb 21, 2012 | 06:36 PM
Fronzizzle's Avatar
Car: 1985 IROC-Z
Engine: 383
Re: MSD-8366 or MSD-5591 for HSR?
In case anyone else was wondering...
Talked to Summit about this. Was told that the 8366 can be used in marine applications and that's why it's more $$$.
Talked to MSD and found out that the cheap one really is cheap. The 5591 isn't even manufactured by MSD, it is made at an outside company and is basically made of all standard material. The 8366 is made in-house and consists of higher end components and materials.
Old Feb 21, 2012 | 09:55 PM
oscarfromla's Avatar
Car: 88 Iroc-Z
Engine: 355 AFR-195 FIRST Fuel Inj.
Axle/Gears: ??
I have the 8366 that's going into my build. Good to know I have the higher end one. Thanks for the follow up.
86z89iroc
Oct 5, 2015 01:04 PM
86CamaroDan
Sep 29, 2015 10:08 PM
mike22115
Sep 28, 2015 04:49 AM
BBSDesigns
Sep 22, 2015 03:08 PM
355tpipickup
Sep 4, 2015 05:32 PM
