carbed 383 to holley stealth ram? need advice
Subscribe
Jul 10, 2012 | 07:37 PM
hey guys, my name is sean and i currently build a 383 it had procomp heads 3003 with 210 intake ports. 160 exhaust.
when i launch my car it has skinny tires but it pulls kinda good till maybe 3500
then 3500 to 5000 seems to lack a lot of power. i have a procomp intake manifold with a holley 670 dual feed carb on it. so my thinking is that the manifold isnt matching up the 210 intake ports like maybe half? would a holley stealth ram match up better does anyone have this combo. would i get a lot more power and top end.
another thing is my dad whos been rebuilding 700r4s all his life just rebuilt mine i put a 2500 stall in it and it doesnt stall its like its stock and it shifts really early and i got the tv cable bracket thing with the spring. could it be the valve body he didnt really go into that .
my main thing is the engine seems like it should have a hell of a lot more power
Reply 0
Jul 11, 2012 | 01:21 AM
Re: carbed 383 to holley stealth ram? need advice
What cam , what CR in engine ?
What rearend gears ?
Reply 0
Jul 11, 2012 | 12:23 PM
my bad thought i edited that in there. its a summit cam 488 510 lift 234 244 duration. have enough advance that it pings when i stomp on it. the rear is out of g92 i think 323 or 340 somethin. im just thining that the intake insint nearly the size of the heads. do they make a carb one that fits pritty close. and its not high rise like the heads need to be or id have to cut a hole in my hood. i would do that 2 for the time being untill i get the new hood. cr should be around 10:1
but had it tuned where it doesnt ping with 93 octane
Reply 0
Jul 11, 2012 | 01:57 PM
Are the intake ports vortec style?
Are the heads dual drilled?
Could just be the procomp heads. They have huge ports but poor flow so they hurt low end.
Reply 0
Jul 11, 2012 | 02:25 PM
not sure if their vortec but the low end is good its the top end and i know their high rise heads and i dont have a high rise manifold. guess im lookin for a good high rise manifold with big ports then intake ports on the heads deff didnt match the heads
Reply 0
Jul 11, 2012 | 02:29 PM
What model procomp manifold do you have?
I looked up the heads and it looks like they are drilled for both manifolds and appear to have a vortec pattern.
You probably need a vortec manifold for optimum performance.
This thread has vortec heads do your intake ports look like these? Or are they the square ports?
You want something like this
http://www.ebay.com/sch/i.html?_saca...k+7116&_sop=15
Reply 0
Jul 11, 2012 | 02:44 PM
honestly i dont remember theirs no markings on it but it wasnt an expensive one
Reply 0
Jul 11, 2012 | 02:52 PM
Quote: honestly i dont remember theirs no markings on it but it wasnt an expensive one
I almost guarantee you need a vortec manifold. What is your max RPM? Make sure you match the manifold to your cam.
http://www.summitracing.com/search/M.../?Ns=Price|Asc
Reply 0
Subscribe
