Fuel Pressure suggestions
Car: 1988 Gta
Engine: 383
Axle/Gears: Stock
I've got a Stealth Ram....on a 383 with 11:1 compression. Where should my fuel pressure be set at roughly? suggestions.
Car: 1988 Gta
Engine: 383
Axle/Gears: Stock
Re: Fuel Pressure suggestions
51 views and no responses. I'm running 28 lb injectors. set pressure at 55...seems to be okay.
Car: 87 monte aerocoupe
Engine: 383 HSR w/ novi 2000
Transmission: Built 4l80e circle d converter
Axle/Gears: Currie 9" 3.89 gears
Mine is at 47 with 48 lbers and a walbro 255 pump. It really depends on what you are tuned for because the pressure will affect how much fuel is being injected. I just set the pressure there, tuned it, and left it alone.
Car: 86 MCSS-87 Z28
Transmission: Auto OD-5spd
Axle/Gears: 3.73 both cars
What ECM are you using? Normally you would set the pressure at 43.5 and tune it there. What pressure were the injectors rated at? If rated at 43.5 and you are running at 55 you have increased them to 31.45 lbs
R3500
Aug 17, 2015 12:16 PM
92camaroJoe
Aug 13, 2015 06:07 AM
