Alternative Port EFI Intakes This board is for tech discussions and questions about aftermarket port EFI such as the HSR, MR, SR, BBK, FIRST, etc.
Fuel return
Old Apr 14, 2013 | 06:54 AM
WASyL's Avatar
Car: 1988 Pontiac Firebird
Engine: 305 LT1 intake&heads
Transmission: TH700r4
Axle/Gears: 3.73 10bolt GM
Fuel return
I did an engine swap to a new car that does not have provision for fuel return in tank form fuel rails (HSR). I'm using external fuel pump and was wondering can i connect fuel return between tank and fuel pump or not
best regards
Old Apr 14, 2013 | 08:50 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: Fuel return
Possible , but elec pumps rely on the fuel flow through them to keep them cool so doing it that way with the line ahead of the pump holding pressure may cause the pump to burn up
Old May 8, 2013 | 10:59 PM
Tibo's Avatar
Car: 1991 Z28 Vert
Engine: 383 single plane efi
Axle/Gears: 8.8 with 3.73s
Re: Fuel return
You should just be able to order a new sending unit for a fuel injected car, that would be the easiest way. You could get one from a junkyard instead but it would be risky if the actual fuel sending unit would still work... Been there done that.
EDIT: do you have junkyards over there? real question, not sarcastic.
Old May 9, 2013 | 02:03 AM
WASyL's Avatar
Re: Fuel return
no us car junkyards here as for FI tank, well my car never was FI. anyways i switched to carb so problem is no more, thanks for the input
best regards
Old May 21, 2013 | 07:53 AM
C409's Avatar
Car: '87 Vette C4
Engine: 400 + .040 = 409 ci
Transmission: 700R4 built
Axle/Gears: Dana 44 w/3.42's
Re: Fuel return
Several companies make a fuel filler hose with a nipple on it to accommodate an EFI motor in an earlier vehicle ... this just replaces the hose between the fuel fill and the tank fill pipe ... it would be the easiest way to accomplish the return line without having to modify the tank itself .......
Old May 21, 2013 | 01:43 PM
efiguy's Avatar
Re: Fuel return
Moroso makes a piece that will do that.
Grant2k
Jul 10, 2018 04:01 PM
anesthes
Aug 24, 2015 08:18 PM
wayshegoes
Aug 17, 2015 12:00 PM
TEDSgrad
Mid-West Region
Aug 10, 2015 07:12 AM
Kaweh
Aug 9, 2015 02:54 PM
