HSR Regulator placement. where?
Subscribe
Jun 8, 2014 | 12:11 PM
Hey guys. I got the chinese HSR and I'm in the process of putting the intake together before actually swapping it onto the car. I'm tossing about the idea of running the regulator either on the firewall or on the fender. I want the crossover to remain on the front of the rails. Can any one show me any pics on how they ran theirs?
Reply 0
Jun 8, 2014 | 02:26 PM
Re: HSR Regulator placement. where?
Quote: Hey guys. I got the chinese HSR and I'm in the process of putting the intake together before actually swapping it onto the car. I'm tossing about the idea of running the regulator either on the firewall or on the fender. I want the crossover to remain on the front of the rails. Can any one show me any pics on how they ran theirs?
one the firewall is not track legal ,
on mine i found it easier to run the x over on the back of the intake
Reply 0
Jun 11, 2014 | 12:07 AM
Are you guys kidding me? THOUSANDS of people see this every day and not one person can help a brother out? Damn dude.
Reply 0
Jun 11, 2014 | 10:14 AM
Quote: Are you guys kidding me? THOUSANDS of people see this every day and not one person can help a brother out? Damn dude.
what are u using for fuel lines, hard lines, braided an, or?????
if u plan on taking this thing to the track all fuel lines/regulator must be foward of the firewall/bellhousing by minimum 6 inches
Reply 0
Jun 11, 2014 | 01:50 PM
I actually have quite a bit of hard lines saved from a sending unit swap a friend of mine did a while back. I also thought about getting a tubing bender and modifing the stock lines to run in the new configuration. I want the regulator to be tied into the back of the rails and the cross over in the front. Mostly for asthetics and cleanliness.I just need to know what fittings I would need to tie it all together.
Reply 0
Jun 11, 2014 | 03:56 PM
Ok upon closer research and inspection I see that it might be possible to cap off the front of the rails and run the cross over under the middle of the plenum. I've also seen other pics of people running both the inlet through the side of the regulator and having the return feed through the bottom of the regulator. Is that possible?
Reply 0
Jun 12, 2014 | 02:04 PM
DON'T USE THE STOCK REGULATOR. They are junk. Get a Kirban, aeromotive or anything besides the stock unit. Then mount it on the driver side end of the fuel rail. You will save yourself a lot of time and headache. I know, I have had one for over a decade. Actually I have two but I haven"t used the second one yet. Great EFI intake though.
Reply 0
Jun 12, 2014 | 02:47 PM
Does the procomp reg have problems? I have found that i'll need 16mm X 1.5 for my cross overs. Where can I find these?
Reply 0
Jun 12, 2014 | 05:53 PM
Quote: Does the procomp reg have problems? I have found that i'll need 16mm X 1.5 for my cross overs. Where can I find these?
why not just do it the right way?
did u buy the procomp rail kit ? it comes with everything u need
then u buy the adapters for the factory hardlines to convert them to an fittings and hook up 2 lines
the adpaters are 21$ on ebay , and a few bucks more from summit
or goto napa and have them make u the lines , u cutoff the stock ends and they will make the lines with compression fittings to go on the factory hardlines
fuel flow is best threw the rail with a front/rear setup
Reply 0
Jun 12, 2014 | 06:09 PM
Thays thing is i do have the rail kit. I bought the reg and rails separately and they still don't have all the fittings i need.
Reply 0
Jun 12, 2014 | 06:10 PM
Do you have a link to these adapters?
Reply 0
Jun 12, 2014 | 06:34 PM
Quote: Do you have a link to these adapters?
here ya go
http://www.ebay.com/itm/TPI-TBI-FUEL...357630&vxp=mtr
Reply 0
Jun 12, 2014 | 07:08 PM
Holy damn. I just went to a local hose and pipe place here in town and found those in brass for three bucks each.
Reply 0
Jun 13, 2014 | 07:43 AM
I removed stock reg ,plugged the hole and fitted a Aeromotive unit at rear of the rail ( clears firewall fine on my Vette , don't know about 3rd Gen )
Supply line to pass side rail , return from bottom of reg
Shown below on my SP intake but same fitment on my HSR , the FP gauge goes in blanked port
Reply 0
Jun 13, 2014 | 12:02 PM
That looks great. Mount it like vettoz has his mounted which is how I have mine mounted also. Then use the stainless braided line and the appropriate fittings. I used Earls I think which is owned by Holley. I think I used -8 braided line but if I am wrong one of the guys will correct me. I did mine in 2003 I think so it has been a while but the main headache I had was getting the fuel right and after two million headaches I found out the factory regulator was CRAPPP!!!. I also punctured every finger trying to get the fittings over the braided hose. Don't economise here since it is fuel under a lot of pressure and very close to the exhaust. I attatched my hose to the hard line at the frame under the brake master cylinder and used two 45 elbows and ran the line back to the firewall and across by the distributor and then to the fuel rails. I also drilled the brass fitting on the passenger side fuel rail up front and installed a fuel pressure gauge. That is how I found out the factory regulator was crapping out. Under accellaration my fuel pressure would fall to less than 20lbs. It is supposed to be at 46 I think. I got 42lb injectors and this thing had no gas off idle. You really need the right fuel rail. You don't need to mess around with fuel. Save a dollar and have a weenie roast.
Reply 0
Jun 13, 2014 | 12:17 PM
Mines on the firewall and tracks have never seen it. Lol
Can do crossover in front with braided line and 2 90 deg fittings. Not the cheapest but works.
Hsr does it with a hardline setup. You could do that and flare your own ends
Reply 0
Jun 13, 2014 | 03:12 PM
Now when you guys are talking about the "stock" regulator, are you talking about the procomp reg or a modified stock tpi reg? I do have a BBK reg I wouldn't mibd converting for this use.
Reply 0
Jun 14, 2014 | 05:07 AM
Quote: Now when you guys are talking about the "stock" regulator, are you talking about the procomp reg or a modified stock tpi reg? I do have a BBK reg I wouldn't mibd converting for this use.
they are talking about the holley reg that comes with the holley kit
Reply 0
Jun 14, 2014 | 10:29 AM
Ah, i don't have that one lol
Reply 0
Jun 15, 2014 | 02:16 PM
The Kirban is very good which is what I went to and the Aeromotive reg has an excellant reputation. Don't waste time or money on the holley regulator.
Reply 0
Jun 17, 2014 | 07:49 AM
I know you said you wanted to keep the crossover in the front but I figured I would post some pics of what I did anyway if it helps. I think it turned out pretty clean, I was happy with it.
Reply 0
Jun 17, 2014 | 08:55 AM
Kirban unit is great for an adjustable with holley rails. Or buy a non adjustable buick GN reg for cheap
Reply 0
Jun 17, 2014 | 01:59 PM
Quote: I know you said you wanted to keep the crossover in the front but I figured I would post some pics of what I did anyway if it helps. I think it turned out pretty clean, I was happy with it.
this is how mine is
Reply 0
Jun 17, 2014 | 02:24 PM
That's actually pretty clean. I like that, I hate being such a **** about a clean engine bay lol. It makes my life such a pain in the a$$.
Reply 0
Jun 17, 2014 | 02:27 PM
What fittings did you use to connect the reg to the stock rails?
Reply 0
Subscribe
