Alternative Port EFI Intakes This board is for tech discussions and questions about aftermarket port EFI such as the HSR, MR, SR, BBK, FIRST, etc.
Need a distributor for HSR
Old Dec 24, 2014 | 09:12 AM
Casey Meyers's Avatar
Car: 86 Z28
Engine: 385 HSR
Transmission: T56 stage 2
Axle/Gears: Moser 9" 3.70 locker
My original in cap hei wont work and holley has not been of much help. I need to find out what distributor will work with the electronic advance of the Avenger HP ECU and what I need to do to use a remote mount coil
Old Dec 27, 2014 | 05:42 PM
soarestransam's Avatar
Car: 1988 Gta trans am
Engine: LR4 4.8
Transmission: 98-02 t56 6 speed
Axle/Gears: Bw 9 bolt (3.70’s) pbr rotors
Re: Need a distributor for HSR
Use a stock hei distributor from a 97-92 tbi or tpi 5.0 or 5.7
Old Dec 27, 2014 | 05:43 PM
Engine: LR4 4.8
For the coil u can use a 87-92 style external mount coil from a tpi or tbi car or truck
Old Dec 28, 2014 | 07:29 PM
Tibo's Avatar
Car: 1991 Z28 Vert
Engine: 383 single plane efi
Axle/Gears: 8.8 with 3.73s
And any external coil you get will work but don't spend extra for a performance coil unless you have the ignition box for it.
Old Jan 2, 2015 | 08:44 AM
Car: 86 Z28
Engine: 385 HSR
Thanks, that makes it much easier
Old Jan 3, 2015 | 10:11 AM
Car: 86 Z28
Engine: 385 HSR
just thought that since the 87 up cars were roller cam, what drive gear do i need for a hydraulic flat tappet? its a comp cams 12-246. should be iron, correct?
Old Jan 4, 2015 | 11:07 AM
Tibo's Avatar
Car: 1991 Z28 Vert
Any distributor will have the correct gear for a hydraulic flat tappet as it's the weakest dizzy drive gear of all types of camshafts
Old May 27, 2015 | 10:52 AM
Zeromitch87's Avatar
Car: 1987 GTA
Engine: 383 HSR
Transmission: 4l60e
I use the msd 8366 distributor and msd 5526 coil with my HSR hp efi without the msd box just fine.
Old May 28, 2015 | 02:51 AM
Tibo's Avatar
Car: 1991 Z28 Vert
Yeah you can run them just fine but they will be no better than the stock setup. You need an ignition box to receive the benefits. Different online thread discussions about it. That's a fact the marketing team does a great job at hiding. It's akin to buying a two step coolant fan or NOS system and never wiring the second step.
Old May 28, 2015 | 11:24 AM
Car: 1987 GTA
Engine: 383 HSR
Transmission: 4l60e
I have the box just not sure how it would work with holley hp efi just yet I know I've seen the wiring diagram for it but just holding off until I work all the other issues out 1st. have not even researched to see if my old msd box would even work with this setup, I used it on my old tpi.
Fanatic1074
Oct 3, 2022 05:57 AM
RedLeader289
May 28, 2019 01:47 PM
HoosierinWA
Oct 7, 2015 10:15 AM
Jlanz55
Sep 29, 2015 08:55 AM
Damon
Sep 26, 2015 04:29 PM
