need some tire help.
Old Apr 23, 2002 | 02:32 PM
maniacc's Avatar
o.k., i originally posted the message below in the suspension/tire/brake forum, but no-one has answered, so i'm hoping someone could maybe give me some insight on what would be the best direction to go...
o.k, it's time for me to purchase some wheels and tires, i have decided on getting a set of ROH ZS wheels and a set of Nitto 555 drag radails for the rear and nitto 555 extremes for the front,
i was thinking about going with 17X9.5 rim for the rear and 17X8.5 for the front, but then comes tire size selections, i decided to go with 275/40/17 rears, but undecided on what size to go with for the front either 245/45/17 or 255/40/17 according to Nitto website they will both fit the 8.5" rim
what are our suggestions?
any problems that i'm not seeing here, please let me know?
later
larry
Old Apr 24, 2002 | 06:58 PM
racereno's Avatar
Car: 91 Camaro RS
Engine: 305 TBI
Axle/Gears: Stock
I beleive the 255/45/17 keeps the same diameter as the rear tire you're goin' with if that matters.
Old Apr 24, 2002 | 07:46 PM
maniacc's Avatar
The 245/45/17 (25.67 overall diameter) is close to the same diameter as the 275/40/17 (25.63 overall diameter), and the 255/40/17 (25.08overall diameter) is about a 1/2" smaller.
i was wondering if there will be any rubbing or handling issues using the slightly smaller (255/40/17) tire, or if it would be noticable (looking at the tires from a slight distance) using a different series tire 45 (front) and 40 (rear).
thanks
larry
Old Apr 24, 2002 | 08:43 PM
racereno's Avatar
Car: 91 Camaro RS
Engine: 305 TBI
Axle/Gears: Stock
I had been loking at Falkens when I saw your question and I am reminded, different company=different diameters. Anyway, if you choose to mix profiles I don't think it will be noticable. I guess if you have clearance problems go with the smaller dia., if not then its your choice.
92-Formula
Dec 12, 2015 10:34 PM
Angie Coots
Sep 23, 2015 07:42 AM
F-body-fan
Sep 17, 2015 12:16 PM
2MNYMaros
Sep 15, 2015 11:36 PM
dennisbernal91z
Wheels and Tires
Sep 12, 2015 12:28 AM
