Zaino users and Zaino-holics step inside >>>>>
Old Apr 28, 2002 | 07:11 PM
Chuck Everly's Avatar
Well I have some good news. I have found a product that appears to be as good as Zaino but cheaper.
It is called Duragloss. http://www.duragloss.com
Rumor is Zaino and Duragloss are the same product but I don’t think so. I will say they apply, remove, feel, shine and in some cases even smell the same.
Agree or disagree with me but you owe it to your self to check it out. If you look back at my old posts I am a diehard Zaino user. I now have a product that I can get locally and it works just as well.
Old Apr 28, 2002 | 10:25 PM
SC82TA's Avatar
Car: 1982 Pontiac Trans Am
Engine: Stock carbed 305
Transmission: Stock 200C
If you read their sites you can tell they aren't the same at all...I'll quote:
Duragloss
DURAGLOSS PCP (#104) contains a blend of waxes, polymeric silicones and mild abrasives. It gives a deep gloss and durable protective coating. DURAGLOSS PCP can be used on both regular and clearcoated paint with excellent results. It is recommended that a section at a time be polished instead of the entire vehicle. For maximum protection DURAGLOSS PCP should be applied twice per year.
Zaino
Z-2 Show Car Polish contains state-of-the-art optical enhancers and gloss additives to show the true color and clarity of your paint. It is 99.9% optically perfect. We also added Ultra-Gard™ UV(40) our advanced technological sunscreen for the ultimate protection against fading and shrinking...Z-2 is a hydrophobic-based formula and contains no abrasives, harmful silicones, or yellowing carnauba wax.
Both descriptions contradict themselves
Old Apr 29, 2002 | 02:40 AM
Jza's Avatar
Jza
Chuck: So you use it now? How long have you been using it?
I will PM you or ressurrect this topic in six months and you let us know how it's held up in the long term, k?
Old Apr 29, 2002 | 04:42 AM
Mirsiro427's Avatar
Originally posted by SC82TA
...Both descriptions contradict themselves
I don't see how the descriptions contradict themselves, did you mean to say they contradict each other?
Old Apr 29, 2002 | 05:05 AM
Equivalent to Z2 ---> DURAGLOSS CCP (#111) is a non-abrasive polymeric silicone formula which gives a "Wet Look" shine and durable protective coating. It is durable to both acid and alkaline washes. DURAGLOSS CCP can be applied to the entire vehicle in the sun or shade before removing easily for a high gloss and protective coating. For a maximum protection, DURAGLOSS CCP should be applied twice per year. Since DURAGLOSS CCP does not contain silicone oils it can, be removed with steel wool and Prep-Solv for re-painting.
Equivalent to Z1 ---> DURAGLOSS (#601) is similar to an epoxy (A & B) which reacts chemically when it comes in contact with durable polishes. DURAGLOSS PP will double the durability and protection of polishes when applied correctly. It should be applied in a thin coat to the entire vehicle; then a coat of polish applied over the DURAGLOSS PP. Allow to haze and remove for a brilliant, durable shine.
Equivalent to Z3 ---> DURAGLOSS PC (#101) contains polymeric silicones which form a protective coating on the surface of painted vehicles. It is durable to both acid and alkaline washes. DURAGLOSS PC also contains a mild abrasive which safely removes fine scratches and mild oxidation. It can be applied in the sun or shade to the entire vehicle before removing easily for a "Wet Look" shine and protective coating. For maximum protection DURAGLOSS PC should be applied twice a year. Since DURAGLOSS PC does not contain silicone oils it can be removed with steel wool and Prep-Solv for re-painting if needed.
Equivalent to Z7--->DURAGLOSS CWC (#901) is a highly concentrated blend of mild surfactants and cleaners that actually enhance the shine of painted vehicles each time it is used. Does not contain acids or alkalies and will not remove durable polishes. Lubricates the painted surface to reduce scratching of dirt and soil when washing. This highly concentrated formula requires only one ounce per gallon of water. Rinses completely.
Jza, Yes I am using it.
If you all have Zaino by all means keep using it. When you run out check out some of your local parts stores and see if they carry Duragloss. I have found that some CarQuest, NAPA and AdvanceAuto stores carry this stuff. I have nothing to gain I am just passing on what I found.
Old Apr 29, 2002 | 05:27 AM
SC82TA's Avatar
Yes Mirsiro427 you're right, they contradict each other not themselves...thanks for catching that. I don't doubt that Duragloss is a good product I have a few friends that have used it before. I just don't see how you can say they're the same when I pointed out the differences. I mean they may have the same function but they aren't the same due to the stuff that's in it.
Old Apr 29, 2002 | 06:25 AM
You are looking at a different product (104) than I used (111). I did not say they were the same I said "they apply, remove, feel, shine and in some cases even smell the same”.
Everyone continue to use what you wish, I am just trying to point out a different product that I feel works as well as Zaino. There have been some arguments on this subject on many different boards so I did a side by side test. I feel they are very close in shine, feel and ease of use. I do not know how long it will last in comparison to Zaino because I polish my cars at least twice a month.
Old Apr 30, 2002 | 06:35 AM
SC82TA's Avatar
You're right about the different product used, but its basically the same thing, the duragloss products contain the things I bolded and and Zaino Bros. doesn't. Regardless it is a good product on its own and it is cheaper, but different. I've seen both of them in person and they look great, but yeah I wouldn't know long term because I haven't used either on my own cars.
Old Apr 30, 2002 | 06:45 AM
You are welcome to your opinion but if you read about the 111 product you will see it does not contain silicone oils, abrasives or wax like you bolded above in the 104 product. So you can see they are not “basically the same thing”.
Old Apr 30, 2002 | 02:57 PM
Karps TA's Avatar
Car: 1985 Trans Am
Axle/Gears: 3.70
This is such a funny thread. Usually it's people arguing about not wanting to use it, this time it's a "discussion" over not wanting to stop using it. LOL
Man I love this place
Old Apr 30, 2002 | 10:48 PM
SC82TA's Avatar
I guess it did turn into somewhat of an argument but I don't have anything against Duragloss or Chuck...just that I know the products are different. Yes 111 is different than 104 I suppose polymeric silicone is not silicone oil. Makes me wonder what the hell Zaino uses, and Duragloss for that matter?
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
1MeanZ
Dec 18, 2015 05:39 AM
New2Chevy
Sep 28, 2015 12:35 AM
Night rider327
Sep 2, 2015 04:18 AM
Night rider327
Sep 2, 2015 04:17 AM
