Sandpaper
Old May 3, 2002 | 07:58 PM
capn_crash84's Avatar
Sandpaper
Hey everyone. I applied three coats of self-etching primer to my engine bay tonight , and i had a whold bunch of runs(i'm not the best painter and that stuff is thin). I want to block sand those out before i put the other primer on, so what grit sandpaper should i use. Thanks.
aaron
Old May 4, 2002 | 01:20 AM
MetalliCamaroRS's Avatar
Car: 1989 IROC-Z
Engine: 383 stroker
Axle/Gears: Moser 9", 4.11:1
I'm no expert, but I'd guess 120.
Old May 4, 2002 | 07:28 AM
88Bravo's Avatar
Car: 1988 Pontiac Firebird, flat black
Engine: Stock 305 LO3
Transmission: Five speed
I would wet sand and start with 400. make sure you use a block and not your hand because it is not even pressure. Do you have a squeegy? Somthing to get the old water out of the way. the best way to paint it to not stay in on place, keep the nozzle the same distance from the surface at all times. And do steady even strokes. not much else I can say without showing.
You can dry sand, but try to keep the sand paper clean, ie old primer. 120 is too low, 400-600 works great. But cloged paper would be like sanding with toliet paper!!
Fronzizzle
Feb 9, 2017 09:31 AM
IROCBandit
Feb 12, 2003 09:26 PM
Black_Widdow
Jan 18, 2002 03:33 PM
elizabeth
Sep 19, 2001 08:05 AM
Rob90TA
Jul 26, 2001 07:16 AM
