*** DaMN MuthaF00kin'...
From: "No one cares if you're in before the lock!" - Best quote ever.
Ok, to remove the marker light on the front drivers side, or at least replace the bulb, and I gonna end up having to remove the headlight assembly....?? What a pain in the ***.....
(87 Bird)...well, I went in there, because my bulb is shot...I figured that it'd be an easily accessable, swap out old bulb/put in new one...but of course nothing is that easy. I tried moving the battery and going in that way, but I won't have the room I need to access the damn thing...just looking for someone who's done this before, I guess. Thx.
Cool, thx bluegrassz, it's just been pouring out over here so I didn't think to crawl under there...I'll get to it as soon as it let's up. That's what's great bout this board, and it's hundreds of thousands of members...quick replies!
:lala:
:lala: Senior Member
Car: 1989 GTA
Engine: 383 Miniram AFR195
Transmission: Tremec TKO
Axle/Gears: BW 9 Bolt/3.70
Azure,
I changed mine from underneath. It is a tight squeeze for your arm but it can be done.
Good luck.
-Schultzy
Good luck.
-Schultzy
Pac J
May 17, 2020 10:44 AM
BumpaD82
Feb 26, 2016 02:57 PM
383backinblack
Oct 14, 2015 08:50 PM
