Bright *** parking lights??? how?!
Old May 14, 2002 | 10:19 PM
1991 Z-28's Avatar
Car: 1991 z-28
Engine: zz4 350
Transmission: t-56
Ok you know how on the new camaros, and especially the new corvettes, they drive around during the mid daylight and have their parking lights on , you know those bright *** orange ones, they look incredibly and you can see them even during the day... if i put on my parking lights, those things are weak as hell and only realllly bright when its blinking, how is it possible to make them bright like that??? and possibly the back tailights that birght too??? thanks
Old May 14, 2002 | 11:08 PM
Jza's Avatar
Jza
Search for "DRL" on the electronics board. You'll find some useful info.
Old May 15, 2002 | 11:06 AM
Twistopher's Avatar
Car: 91 Z28 Convertible
Engine: 305TPI
You can always upgrade the bulbs that you use. I think they make bighter bulbs in the same size that you can upgrade to. Also there is an LED style replacement. They can be found and some auto parts stores. Try doing a search for something like LED taillights. The front parking lights use the same bulb as the taillights. The bulb number escapes me at the moment. The LEDs yield a much higher light source. Not sure how well it reflects though since they are LEDs. Just some thoughts.
Old May 15, 2002 | 09:10 PM
trigger GTA's Avatar
Car: 92 TA vert
it can be done. in Ontario Canada its law that after 89 ALL cars have the day time running lights. see what the difference is between our cars and yours and make the mod. OR just buy a Ontario car
Old May 15, 2002 | 09:26 PM
MetalliCamaroRS's Avatar
Car: 1989 IROC-Z
Engine: 383 stroker
Axle/Gears: Moser 9", 4.11:1
I think it can be done with the flasher. Cause my hazards flasher was shot and when I would turn on my hazards, they would just stay on bright and not blink. I don't know if this will work, but what if you pulled the hazards flasher and your rear turn signal bulbs. Then put the hazards on? I don't think they will blink to bright though without the flasher. Hmm.., I don't know how mine did it.
Old May 15, 2002 | 10:14 PM
Twistopher's Avatar
Engine: 305TPI
Originally posted by trigger GTA
...OR just buy a Ontario car
but if he did that then the wheel would be on the wrong side of the car...
LittleFranks
Sep 17, 2015 12:22 PM
Jk_Under
Sep 2, 2015 10:59 PM
tnrednneck
Aug 13, 2015 08:57 AM
Omega
Aug 10, 2015 12:46 PM
NBrehm
Exterior Parts for Sale
Aug 5, 2015 08:19 PM
