exhaust
Old May 15, 2002 | 02:47 PM
wonderwoman's Avatar
exhaust
I took my car in to the exhaust center here today and they told me , that no way would I beable to run my exhaust out in front of my rear tires. I believe they are full of sh**, if anyone one is from the Georgia area or knows if this can be done please let me know
This is a pic. of my car..
Old May 15, 2002 | 03:59 PM
TonyC's Avatar
Car: A Camaro
Engine: Weak
Transmission: Weaker
Sorry, it's sort of off topic, but why is the rear end jacked up like that?
Old May 15, 2002 | 04:02 PM
AIR SHOCKS
Old May 15, 2002 | 04:16 PM
redraif's Avatar
Car: 87 Red/Blk Bird loaded 3.4L & 700R4
Transmission: Th700R4
Don't know if it possible, but...
I don't know if they can help, but give my guys a call.
All Pro Muffler: 770-478-1507
9212 Poston Rd.
Jonesboro, GA. 30138
They have done great work for me in the past. If it can be done, I'm sure they can find a way. They set up my 4 centered tips with no problem. Really great guys.
Tell them Shannon with the red firebird recommended them.
Old May 15, 2002 | 04:25 PM
Redarrow1's Avatar
Car: 2001 Firehawk - SLP Longtubes
I know you didn't ask for an opinion but I find myself compelled to give you one. Please bring the rear of that car back down. Your car looks good other than that. I just think it looks way too seventies/trailer trashie. But then again opinions are like azzholes...
Starsky & Hutch have left the building.
Old May 15, 2002 | 04:41 PM
The whole idea of airshocks is to raise and lower them when ever I feel like it!!! I have changed tires on the rear so it had to be lowered for now!!!!! I do not mind your opions, although I did ask for help with info. on an exhaust!!
Old May 15, 2002 | 04:49 PM
Redarrow1's Avatar
I thought the whole idea of air shocks was for when you were towing a trailer. But anyway.... If you are going to run straight pipes, you should be able to have the pipes exit on the passenger side and perhaps the driver's side as well. If you are gonna run a muffled system, I think you will run into clearance problems. Maybe a set of cherry bombs will fit under there, but then you get into that whole trailer scene again. Good luck.
Old May 15, 2002 | 04:58 PM
Basett_Racing's Avatar
The rockers on our cars come down kinda low, and as bad as I hate to encourage you to do it, I have seen a Firebird that was done that way, but it looked terrible. It, coincidentally, DID have glasspacks on it, and it also sounded terrible. But to answer your question, it is possible, but not advisable!
Old May 15, 2002 | 07:00 PM
86Street's Avatar
believe me. you will run into clearence problems if u have mufflers on there. i do on mine. and i have air shocks too. everyone on this board thinks if ur rear end is higher then the front its trashie. said the same about me. granted i think you should get some bigger tires. not lower the car. just get bigger tires. but u will have problems with the whole clearence. by the way if u ever wanna talk my aim name is
allen7dust
this is my sexy car.
:hail:
Old May 15, 2002 | 08:41 PM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
It can be done, CarNDrvr's car had dual side exit exhaust.
Old May 15, 2002 | 09:06 PM
Thank you , for all your comments , all is appreciatedand i will be in touch.
Old May 15, 2002 | 09:07 PM
1991tealRSt-topGuy's Avatar
Car: 1991 Corvette Coupe
Transmission: 700R4/4L60 same trans different name
when its done correctly it will not look like trailer trash
as in...........bigger tires in the rear, and drop spindles in the front
that blue camaro at the top is WAY too high in the rear IMHO
looks trashy
Old May 16, 2002 | 12:51 PM
To each his/her own opion. I sure there are things bout your car no one else likes either, but as I said to each their own opion.
Old May 16, 2002 | 01:02 PM
Redarrow1's Avatar
Third gens first annual spelling bee.
First up Wonderwoman:
Ok here we go. Spell OPINION.
Wonderwoman: o...p....i...o...n
Awwww too bad it's spelled OPINION.
Thanks for playing. And just for participating in our game
you will be given free fuzzy dice.
The first time you spelled it that way I thought
it was a typo but after you spelled it like that
two more times I figured you just didn't know how
to spell it.
Sorry, I've been cranky all week. I think I need a laxative.
Old May 16, 2002 | 01:53 PM
more like you have been bit pissy.!!!!!!!!!!!!!!Maybe you will be off the rag soon !!!
Old May 16, 2002 | 01:59 PM
85wilrocu's Avatar
Air shocks are cool!
Old May 16, 2002 | 02:01 PM
Bluebird's Avatar
Car: 1991 Pontiac Firebird
Transmission: 700R
IMO
In my OPINION, I would say it is unwise to run the exhaust
out front behind the front tires...
#1) heat.. it gets very hot, when idle.. and if you sit at a light with the windows down you will get all the exhaust in your window.. specially when it's cold outside and the exhaust condenses....
#2) it will look bad
#3) problems doing it...
#4) Issues with the police and local and State laws...
As for the back end being up in the air..
Old May 16, 2002 | 02:12 PM
Redarrow1's Avatar
Actually, if it is done correctly it doesn't look bad. ie. with good tips and good hangers. I don't think heat will be too much of a problem, just angle the tips down and toward the rear. My old formula had the same setup with straight pipes and I never had any problems with heat or exhaust getting in the car. It kind of had a nascar look to it.
zapr
Jul 27, 2018 06:03 PM
PurelyPMD
May 5, 2016 04:57 PM
86White_T/A305
Mar 6, 2016 01:48 PM
1992Z28!
Nov 19, 2015 07:33 AM
david068513
Sep 18, 2015 10:36 AM
