what grit to rough-up old paint??
Old May 30, 2002 | 06:06 AM
1991tealRSt-topGuy's Avatar
Car: 1991 Corvette Coupe
Transmission: 700R4/4L60 same trans different name
220??
i'm gonna rough up my old paint b4 i take the car to get painted..........its all in good shape, but its faded to hell and my front end is in primer
so far, i primed the front fender and the pass. side GFX and then wetsanded them with 400 grit they came out really smooth, but i still have some little crevices in them, whats the best way to get these crevices out?
Old May 30, 2002 | 08:31 AM
GKK's Avatar
GKK
Car: 91 Camaro RS Update: Sold Camaro, now own a "91" Corvette.
Engine: Corvette L98 TPI
You need to Primer those crevices again and spray some Guide coat on and re-blocksand the primered areas with 400 wet. The reason you use Primer is to fill in little imperfections in the surface. Wet sand the entire car with 400 grit to prepare it for paint.
Old May 30, 2002 | 07:10 PM
ok thanx man.........
there more like little rock chips in the paint
i used crevices before for lack of a better term
what if i put a little bit of bondo into them?
Old Jun 3, 2002 | 02:55 AM
JACKO's Avatar
SOUNDS LIKE YTOU NEED TO USE PRIMER FILLER?
OR SPRAY PUTTY
Old Jun 3, 2002 | 04:59 AM
EvilCartman's Avatar
Car: '82 Z28
Jacko, can you lay off the caps lock please?
Body filler (Bondo being one) is usually for the bigger jobs, you need some glaze puddy, it's like body filler only thinner. It would do a better job for filling in chips and small dings.
Old Jun 3, 2002 | 06:52 AM
82camaro's Avatar
Car: 82 camaro SC
Bondo glazing compound--Walmart has it.
Hotrodboba400
Dec 10, 2019 07:07 PM
Drone358
Sep 21, 2015 08:54 PM
TheExaminer
Sep 6, 2015 11:40 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
