what are all these wires and help hiding them
Old Jul 11, 2002 | 01:04 AM
hot86z-28's Avatar
Car: 1992 Camaro RS
Engine: 305 TBI
Transmission: 700R-4
ok guys. i finally found a pic of somebody with a motor that looks like mine. with all the wires around. so i want to know how to hide them and stuff like that so the engine bay looks cleaner.
this is castrolSi(i think that's his name) motor. i hope u dont mind me using it for my pic. it just looks the same.
Attached Thumbnails what are all these wires and help hiding them-donecarb.jpg
Old Jul 11, 2002 | 03:10 AM
RSFreak's Avatar
Car: 1985 Camaro, 1986 Trans Am
Engine: 5.0L carbed and 5.0L TPI
Transmission: TH700R4
Axle/Gears: 3.23 and 3.27 posi
The only wires that are really visible in that pic are the spark plug wires. The main thing hiding that engine are all the hoses! The LG4 in my '83 Z looked like that too. It was a big mess! I had a LB9 in my '85 and it looked a little cleaner. My LO3 is much cleaner (more organized looking that is) than the other two. I think Chevy started routing the wires and hoses in a more logical fashion as the 3rdgens progressed. I removed the coolant bypass valve and all the emissions stuff since this pic was taken. I'm gonna get rid of the AC next (once I get a delete pulley), that should clean up the engine compartment nicely.
Old Jul 11, 2002 | 01:50 PM
slickrock55's Avatar
Car: 82 Trans am
Engine: Twin turbo 350
Well, you could pull the AC, get rid of all that emissions crap (mine *fell* off. . ), you're sort of stuck with the heater hoses, radiator hose, and plug wires, but once the ac and the emissions is out, i think you will be a lot happier with your engine bay.
Old Jul 11, 2002 | 03:20 PM
1986redbird's Avatar
all that, and sometimes a good cleaning will make a world of differance.
Attached Thumbnails what are all these wires and help hiding them-engineafter.jpg
Old Jul 11, 2002 | 03:32 PM
castrolSi's Avatar
I am going to make the attempt to replace and reroute most of
those nasty vacuum lines. A thorough cleaning is also on the "to
do" list. I have never SEEN so many vacuum lines in all of my life.
I am getting rid of that nasty charcoal canister and that junk which
should knock down about 30% of those things. Of course, I wanted
to get a pic like that so I can later show the before and after
~castrol
Old Jul 11, 2002 | 07:00 PM
SLZ's Avatar
SLZ
Though I never had that kind of problem with the engine bay, my eng bay w/ a TPI eng assy still had its stock mess. I ended up taking alot of time and patience in rebundling, rewiring, rerunning hoses, relocating misc things, pulling the entire AC system(I have t-tops and headers so I needed the room), modifying/installing a non AC unit w/ retaining the circuits to control all the climate controls. Just alot of organizing and cleaning. Heres a pic of my eng bay to see what I did. Good luck in your project STEVE Z
Attached Thumbnails what are all these wires and help hiding them-eng-frt.jpg
Old Jul 12, 2002 | 10:36 AM
Knight350's Avatar
Looks good guys, I like the red air cover,very nice..
But I have to ask Steve Z where you got the air filter extensions like that!!! Do you have 2 cone filters on or did you run it under the car for a ram air set up... that would be perfect and pretty easy to do..
Thanks and great job..
Fredel
Old Jul 12, 2002 | 12:20 PM
CustomX's Avatar
Car: 90 irocz
Engine: 350tip
get rid of most of the total bs in thier...
Old Jul 12, 2002 | 03:18 PM
leirch's Avatar
You don't need the heater? Just need a bigger motor
Attached Thumbnails what are all these wires and help hiding them-87iroc40.jpg
Old Jul 12, 2002 | 03:28 PM
KlayBuRn's Avatar
CustomX: What is that thing where you put your oil cap on?
Old Jul 12, 2002 | 08:07 PM
CustomX's Avatar
Car: 90 irocz
Engine: 350tip
its a valve cover breather.
Old Jul 12, 2002 | 10:15 PM
KlayBuRn's Avatar
What does it do ?
Old Jul 13, 2002 | 10:58 AM
CustomX's Avatar
Car: 90 irocz
Engine: 350tip
helps to keep crankcase pressure down at high rpms. Its like a pcv on crack. its also illeagl for smog, so i have to put the oil cap back on. in all honesty, the car doesnt "need" it. although it doesnt hurt it, and it looks cool. if i had a 327 with a mini ram and turbos, youd see 2 of these but alas i dont
Old Jul 14, 2002 | 02:14 PM
SLZ's Avatar
SLZ
The dual air inlet system is from SLP(for speed density but I modded it for MAF)and that t-duct goes to an airbox on either side(that takes the cylindrical style K&Ns). The airboxes have a huge opening on the side that gets all the air from the fenderwells. It made a real difference in breathing vs the stock air canister I had with the little opening(like breathing thru a straw). STEVE Z
Old Jul 15, 2002 | 01:39 AM
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
Here is what my 2 previous setups looked like,
The first one,
The second one,
The third setup is going to be completely different, LT4 with the Hot Cam,
Old Jul 15, 2002 | 09:14 AM
erictheviking's Avatar
Car: '92 RS Camaro
Engine: 406ci D1SC SBC
Transmission: TH400
Axle/Gears: 9" W/Truetrac
I've junked the A/C,smog gear and run a carb.With all this gone you could remove a substantial amount of wiring as theres not a lot needed for whats left.If you were ambitious you could re-route the wiring either inside or under the top frame rails (the ones that hold the fenders on).
Old Jul 15, 2002 | 01:22 PM
5SIZ's Avatar
Car: 1987 IROC-Z
What the hell does completely redoing your engine bay have to do with T-tops? Oh, you now have a new place to store them where the A/C was LOL
j/k
Old Jul 15, 2002 | 01:59 PM
SLZ's Avatar
SLZ
Having no AC equipment makes way for lots of room especially having headers on the car. Having the t-tops off keeps me cool enough. STEVE Z
Old Jul 15, 2002 | 02:04 PM
5SIZ's Avatar
Car: 1987 IROC-Z
oh ok
I misunderstood what you put, I completely understood the header part, it really helps, I know but the T-tops part was wierd lol
Glowsock
Jan 9, 2017 04:06 PM
Caspar
Jun 19, 2016 11:19 PM
ndndndnd
Carburetors
17
Sep 5, 2015 06:24 PM
Bryan F
Aug 27, 2015 07:28 AM
blacksunshine'91
Interior Parts Wanted
Aug 10, 2015 12:04 AM
