Z THANG's Engine Bay
Old Jul 11, 2002 | 07:14 AM
Z THANG's Avatar
Here's a few pics of my engine bay after I dropped my fresh 355 in it.
Old Jul 11, 2002 | 07:26 AM
bluegrassz's Avatar
Car: Camaro
Engine: Carbed L98
Transmission: TH350
nice job man. What kind of header are you going to use? and what size carb is that?
You will need to take it to the track when you get it broke in.
I will keep a eye out for you in corbin.
Old Jul 11, 2002 | 07:51 AM
Z THANG's Avatar
Those pics are about a year and a half old. I had just dropped the motor in and hadn't even hooked anything up yet.I don't have any recent ones. I am going to get a friend of mine to take some with his digital camera and I will get them posted.
The carb is a Holley 750 Vacuum Secondary. I would have preferred a DP, but I already had it and thought I would use it. A friend of mine took it to a machine shop where a friend of his works and he milled the choke horn and polished it out.
I had to use Hooker Super Comp headers. I got the Alumacoted ones. ($540) They were the only headers that would work with AFR angle plug heads. AFR failed to mention this when I ordered them.
Here is a basic list of what the car has on it........
355 Small Block
Air Flow Research Aluminum Heads
Hooker Super Comp Alumacoted Headers 1 3/4"
Comp Hydraulic Roller Cam, Pro Magnum Roller Rockers
Air Flow Research Polished and Port Matched Intake
2 valve relief flat top pistons
Moroso 7 quart pan with windage tray and scraper
MSD 6-AL Ignition with 2 Step
Line Lock
Holley 750 Carb (Milled and Polished)
K&N Filter with X-Treme lid
Weind Aluminum water pump
Moroso Cool Can
Holley Electric Fuel Pump (Blue)
3" Exhaust into Flowmaster 2 Chambers
700 R4 with:
Kevlar Racing Bands
Cyclone valve body
13 vane race pump
Borg Warner High energy clutches
Billet Servos even in overdrive
Precision Industries Vigalante Convertor
Borg Warner Rear with 3:45 gears
South Side Machine Lift Bars and Subframe Connectors
8 Point Cage
15x8 Weld Draglites with 265/50/15's front
275/50/15's back
Old Jul 11, 2002 | 07:56 AM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
Killer engine.
Old Jul 11, 2002 | 07:53 PM
MetalliCamaroRS's Avatar
Car: 1989 IROC-Z
Engine: 383 stroker
Axle/Gears: Moser 9", 4.11:1
:hail: :hail:
Orr89RocZ
Apr 25, 2016 08:28 AM
Reddeath210
Oct 6, 2015 08:20 AM
Polo Z03
Sep 10, 2015 06:43 PM
AkDrifted
Aug 17, 2015 07:45 PM
jahblah
Aug 12, 2015 05:54 PM
