will these wheels work
Old Oct 13, 2002 | 01:17 PM
89firechicken's Avatar
i found a set of fikse for a awsome price but the problem is fitting. the backs are 295/35-18 on 10" rims and the fronts are 235/40-18 on an 8" rim and backspacing 6 1/8" front 7 3/8" rear now i know thats too much but is it possible to get them to fit some how or should i pass.
Old Oct 13, 2002 | 09:12 PM
devianb's Avatar
It's possible. If the have Fiskes have the same bolt circle, you should be able to get adapters to make them fit.
Old Oct 13, 2002 | 09:23 PM
TheWraith's Avatar
Car: 1987 Camaro IROC Z28
Engine: 355
Transmission: 1994 T56
Axle/Gears: BW 3.27 (stock)
what's the bolt pattern? if it's the right bolt pattern, 5 x 4.75" (?), you can easily run them with spacers, but it will cost probably $300 - $400 for the spacers, and you're gonna have to do some measurements on the car to determine what size spacer to run in the rear.
The front is easy, you will want to get approx 4.25 - 4.5" backspacing up front, and you'll be in good shape. Since the rims are the same 8" width as stock rims, you won't have any problems.
but if you run the stock 5" backspacing in the rear with a spacer, then the wheels will stick out 2 inches further than stock on each side, which i think is gonna be too much. Ideally, you'd want around 6" backspacing in the back, but that backspacing might rub, so you're gonna need to measure it out, and find the happy medium that works.
I know there's some people on this board with 11" wide Zr1's in the back, so maybe they could prove helpful with an optimal backspacing.
Old Oct 13, 2002 | 09:25 PM
devianb's Avatar
What kind of deal did you get on those Fiskes since they are like $800 per wheel.
Old Oct 14, 2002 | 01:47 AM
it uses a porsche style bolt pattern. but i belive a skult.com they say the can make a spacer for anything. i just wasent sure if it had too much backspacing and it wouldent work.
Vintageracer
Jan 10, 2020 05:33 PM
Scorched1984
Wheels and Tires
66
Apr 16, 2016 06:56 PM
1992rs/ss
16
Jan 28, 2016 09:58 PM
milk
Aug 10, 2015 06:26 PM
Keiffer76
Car Audio
Aug 9, 2015 11:37 PM
