all 4 headlightswith side lights
Car: 83 berlinetta
Transmission: th 700
i thought you might be interested in this little up grade. i didit and it looks way cool. you never have a dead set of inner lights by having side light bulbs in the inner 2 as well.i am not going to go into every tiny detail because the basic crack is to get hold of 2 more outer headlights & make them fit the inner.there will be a locatoin stud on the back that will be to wide just saw it through & squease it to gether. then run a spur off the original side light wires. beware the hardest part i found was to make the conversion plate for a single bulb to fit the dual bulb hole. you guys over there might be able to buy 1 because i know that they exist i have seen them in buses in the uk but they will not sell them separate. good luck hope its useful
Car: 83 berlinetta
pics
pictures are still in the camera i will get them sorted so watch out for the subject title again soon and i will hopefully have something to show you
Car: 1989 IROC-Z
Engine: 383 stroker
Axle/Gears: Moser 9", 4.11:1
Originally posted by Mark A Shields
You're all ******.
You're all ******.
But then you would have no high beams. You need high beams in the highway.
What he did was, stick a low beam light in the high beam hole and split the wires. So now, when you turn on your headlights, all 4 of them turn on...low beams.
Personally I wouldn't do it.
Car: 83 berlinetta
pics of 4 lights
no to the strange highbeam question
u have the same as be4 just with side lights in the inner 2 as well as the outer
better pics on the other subject title 4 light pics
Car: 1991 T/A - Sold (sniff) 1980 T/A Pa
OH I get it now! DRL (Daytime running lights), putting the small DRL bulbs in all 4 units instead of just the low beams. Thats only for the people that already have the H4 bulb conversion. It won't work for us sealed beamer's. Cool mod, I like it!
