T-Top rust
Old Nov 8, 2002 | 09:20 AM
joshp14's Avatar
T-Top rust
I'm sure that all have you have seen the t-top rust that accurs on the black metal bar that runs between the t-tops. Mine has rust on the black bar along where the weatherstripping runs along the top. How can one fix that? Could i take it off, wire brush it and repaint it? Or should i just get a new one in better condition? I have seen some on eBay for $50-60, but I'd rather not pay that much for one if I don't have to. Any suggestions that have worked for others? Or does anyone have one they will sell to me for a good price?
Old Nov 8, 2002 | 10:01 AM
83firebirdS/E's Avatar
Car: 1983 Firebird S/E
I would go to a bone yard. Usually you will be a ble to find a nice one there. Personally I would not fix the rust I would just replace.
Old Nov 8, 2002 | 10:45 AM
bubbakutz's Avatar
Car: 1987 "1991 Z" Sport Coupe
Engine: LG4
Transmission: TH700R4
hey,
i had the same problem with mine. i had mostly suface rust on mine but a couple spots on the lip of it were eaten through. i just took it off, sanded it down to the metal, spray painted primer on it and then painted it somewhat custom. it was easy and only cost my like 10 buck in paint rather then getting a whole new peice for a lot more. and it looks great too.
bub
here is what it looked like before
Old Nov 8, 2002 | 10:46 AM
bubbakutz's Avatar
Engine: LG4
and after i painted it and put it back on the car with new weatherstripping
Old Nov 8, 2002 | 12:31 PM
Andy Fanshawe's Avatar
Car: 91 camaro rs
I drilled out the rivets, and split the whole thing apart. If I remember correctly, I had to split some welds apart from underneath. Then grit blasted, painted with weld thru primer, spot welded back together and then top lip rivetted back on. Satin black later and done.
I will see if I can find some pictures later. I did this about 5 years ago, so excuse the finer points!
Andy
Old Sep 2, 2017 | 02:57 PM
geoffhughes1986's Avatar
Re: T-Top rust
Andy
Hey man how did you manage to rivet it back together. I'm screwing right now as my rivet gun nose is too wide to fit in to rivet it back!
Jorlain
Exterior Parts Wanted
Jun 29, 2017 11:04 PM
Fireslash
Apr 11, 2016 06:43 PM
Thirdgen89GTA
Nov 26, 2015 11:04 PM
meeklay812
Oct 1, 2015 03:46 PM
tcflint
Sep 27, 2015 05:58 PM
