'79 Front End
'79 Front End
I know this isn't a 3rd gen question, and i'm sorry, but i was just wondering if anyone here is a 2nd gen fanatic and can answer this question. If i have a 79 camaro Z28 with a accident damaged front end , which other years of the 2nd gen camaro have compatible front ends? Thanks in advance for any info you might have.
Car: 85 Iroc-Z
Axle/Gears: 10-bolt 3.42
try asking over at http://www.nastyz28.com they might be able to help u a lil.
Car: 04 Xtreme Blazer
Engine: 4.3L V6
What parts do you need, I live near detroit michigan and have a nose piece, inner fenders , one fender(I think pass, not sure, have to look) and a z-28 hood , all off a 79 Z-28, dark blue, but need painting, make an offer if you want any of it
Car: 86 IROC Convt
Engine: 305TPI
Transmission: TH700R4
Depends on what you mean with "compatible"
All second gens will infact fit i.e. they will bolt up to your 79. However, the 78-81 is the same style front clip as your current one and the fenders will correctly line up with the body molding of the doors. The earlier ones (70-73) will for sure have a different molding, but I cannot recall if there is a difference between the 74-77 fenders and the 78-81, but I do not think so. If that is correct, you can use any 74-81 fender and then get the front clip of your choice.
Ken <~~old 2nd gen lover
Terrell351
Jun 13, 2021 01:13 PM
