Windshield washer system problem...Sorry if it's in the wrong forum.
I didn't know what forum to post this under, so I apologize if this isn't the right one.
I'm having trouble with my windshield washer system. The wipers work fine, but when I attempt to wash the windows, no windshield washer fluid comes out.
I can hear the windshield washer fluid pump working and there are no puddles/leaks that I can see. Everything appears to be hooked up correctly.
Can anyone take a guess as to what can be wrong, would it be a logical assumtion that one of the hoses are blocked?
Try airgunning the lines. If you don't have one, start blowing in them and see if you can locate the blockage. If the pump works, then it has to be the lines.
Most auto parts stores sell new lines so if you locate the blockage but can't unblock it, you can replace that section.
Start with the ends where the water comes out and start with the reservoir where the water goes in - most blockages occur in those two places.
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Seems to me that when I had a similiar problem, the pump made a sound but did not function. I replaced the pump and all was well.
JamesC
JamesC
Car: 86 TA
Transmission: 700R4 - 2200 stall
Axle/Gears: 3.42 posi
same here. just b/c it makes sound doesnt mean it works. i think they cost about $18. new ones are more powerful tho.
Try to prime the pump by blowing some waater into it. They tend
to dry out from lack of use and engine heat. I would try this before buying a new pump, however; they are not that hard to change.
92projectcamaro
Jan 18, 2016 08:00 AM
TheTraut88
Sep 7, 2015 05:22 PM
