H4 Headlight conversion...
i have a 1992 z28 adn am purchasing the h4 conversion kit for my headlight. i have heard that i have to do some alterations to the wires on the bulb to make them work on low and then switch off when the highs are on..in other words...to act normal. please tell me exactly what i ahve to do to make them work right.. i am also wondering if the same kits will work for the high beams...i dont think so cuz the high beams only have 2 contacts and the highs have 3...anything u know will help thanks...
doug
doug
It's been a while since i re-searched the subject, but the deal with the headlight wiring harness is that the factory one cannot support the current that the new and improved high-output ligths will be drawing. There was a kit out there at once time that was wired into the stock headlight harness and the battery and used specialized relays for the headlights.
Car: 87 IROC-Z
Engine: =350 sbc
Transmission: TH350
I had them on my car and i made the wiring harness.Do your self a favor dont get the there a pain in the but.Mine would go out after awhile.So i went with sylvania cool blues...
I'm assuming that it would allow you to change your headlights from being capsule lights, to just bulb lights? I hate having to replace the entire light, when it would be easier to replace just a bulb. Sorry I'm a newbie.
Originally posted by Doogie92Z28
JZA,
so if i just splice the wires to make the ones from the car match up with the ones on the new h4 bulb...it will work like it is supposed to?
doug
JZA,
doug
