Interior question.
Old Dec 19, 2002 | 04:38 PM
TorchRay's Avatar
Car: 89 WS6 Formula
Engine: 305 TPI w/ some mods done
Transmission: Modified THM700R4
Interior question.
Ok guys and gals...im going to try and explain this best i can. Interior of my car....drivers side....on the leftside of the headlight controls. You can see it better if you open the door......anyways...theres a flat black peice of plastic....right under the corner of the dash pad. Is this peice removable?...or does it attach all as one piece and youd have to take the whole dashboard apart..? If your confused let me know and ill try to explain it better. Thanks.
Old Dec 23, 2002 | 01:59 PM
johnnyformula's Avatar
is it the vertical part between the side of the dash & the door?
Old Dec 23, 2002 | 07:25 PM
TorchRay's Avatar
Car: 89 WS6 Formula
yeah i believe so....its about 1/2 inch wide if you look at it from the front. The drivers side air vent from the front is to the right if it.
RyanJB
May 7, 2016 06:23 PM
fbodyfreakls1
Oct 6, 2015 06:34 PM
corey8084
Sep 17, 2015 02:56 PM
MORREALE5
Sep 13, 2015 09:01 PM
Ian Irvine
Sep 4, 2015 08:08 AM
