Cowl hood help
Old Jan 2, 2003 | 12:38 PM
fast89RS's Avatar
Car: 1989 Camaro RS
Engine: Vortec 350
Transmission: Built 700R4
Cowl hood help
How big is too big? The way my engine is right now, the very top of the carbeurator sits nearly a 1/2" above my stock hood. This is without an air cleaner. Plus I would like to run a spacer. So far, only a 2 1/4" and a 4 3/4" hood fit my pricerange. I would like to get the 2 1/4 because it is not completely open on the underside, like the 4 3/4 one is. Also, using pins are much cheaper, should I go that route? Thanks for your help.
Old Jan 3, 2003 | 11:13 AM
bad82camaro's Avatar
wELL I THINK pin's wounld be nice when you want to work on your car because you pull the pin's set the hood aside and you've got all kinds of room to work on your engine,and i would go with 4''or4.5''to make sure you've got the room. mine is not a pin type i don't like the pin's sticking out of my hood,thats just me....
Jorlain
Exterior Parts Wanted
Jun 29, 2017 11:04 PM
91TTOPZ
Exterior Parts for Sale
Sep 20, 2016 12:42 PM
