TPI porting pic
Old Jan 14, 2003 | 03:53 PM
IROC_5796's Avatar
Car: '91 vert RS, '82 Z28
Engine: TBI 305, TPI 350
Transmission: Auto, 5 speed
TPI porting pic
looking at this pic is it okay to remove so much material behind the TB. It looks as though theres holes created, does anyone know if this affects anything? I read somthing about it affecting the egr valve!
Old Jan 14, 2003 | 04:49 PM
IROC_5796's Avatar
anybody know anything on this?
Old Jan 15, 2003 | 02:41 AM
92 Formula's Avatar
From: Avatar: My 34' 1989 Scarab III w/ twin 454's (502's Started!)
Car: 1989 Wellcraft Scarab III
Engine: Twin 454's
Axle/Gears: Twin Mercruiser Bravo I's
You might have better luck on posting this on the TPI board. I've seen several threads on the TPI board concerning porting the TPI, but since I'm no expert I will only suggest posting on that board.
Good luck.
Old Jan 15, 2003 | 03:13 AM
Ward's Avatar
Car: 1988 GTA
Engine: 5.0 TPI
Axle/Gears: 9 Bolt, 3.45
92 Formula, what color is your car? I can't tell if its black or green. In your sig pic, it almost looks like the same color of green as the 92 Heritage edition camaros. Do you have any more pics?
Old Jan 15, 2003 | 09:45 PM
92 Formula's Avatar
Engine: Twin 454's
Hi Ward,
The Formula is Dark Green Metallic, original paint still. The only other pics I have is in the Reader's Rides. I was going to change it to dark red metallic like my old '91 RS was, but I think I will keep it this color.
Thanks.
Old Jan 15, 2003 | 09:58 PM
Fastcamaro87's Avatar
those holes are for the egr they are there already, there is a wall about 1/4 maybe more in front of them, and on the side. u need to remove the walls , u will definitely have better luck posting this on the tpi board, actually just do a search u should be able to find everything u need to know.
Vintageracer
Jan 10, 2020 05:33 PM
Fast355
Dec 2, 2016 06:33 PM
LT1Formula
20
Nov 14, 2015 12:02 AM
Sanjay
Aug 12, 2015 03:41 PM
mx127
Aug 10, 2015 08:13 AM
