smog pump?...
Old Jan 19, 2003 | 07:18 PM
600_dollars's Avatar
smog pump?...
I was wondering if i really need a the smog pump , i mean it doesnt look pretty ?.. and i bet its just extra weight for no reason can i take it out ? or atleast just take the damn belt off?!
Old Jan 19, 2003 | 07:21 PM
FLYNLOW92rs's Avatar
Yes you can.....unless you have emission testing....
Do a search or check the tech articles on the main page for more info.......
Old Jan 19, 2003 | 09:05 PM
MdFormula350's Avatar
https://www.thirdgen.org/techbb2/sea...der=descending
ran a search for you :lala:
Old Jan 19, 2003 | 09:07 PM
TransAm12sec's Avatar
Car: 1982 Trans Am
Engine: LG4
Transmission: 200C
Axle/Gears: 3:73
Is it a bad idea to not have the smog pump and still use a cat?
Old Jan 19, 2003 | 10:01 PM
brodyscamaro's Avatar
Car: 1999 Yamaha Banshee
Transmission: 6 spd manual
Axle/Gears: 14/41 tooth
i dont know - but the simple solution is to remove both...
Old Jan 19, 2003 | 10:07 PM
Jim 86 Bird's Avatar
Car: '89 TA
Engine: LB9
Transmission: M5
Its quite alright to run a CAT w/o a smog setup. I've been doing so for about 2 years now. You can even order a CAT w/o the AIR tube if you like. For further information the search'll help, its had quite a few posts dedicated to it.
italiano67
Dec 11, 2016 09:21 AM
gta90
Sep 15, 2015 04:00 PM
Victor6
Aug 30, 2015 02:09 AM
camaro_rs350
Northern California
Aug 18, 2015 12:38 AM
