Lowering springs?
Old Jan 23, 2003 | 08:28 PM
LPE383's Avatar
Car: 84 Z28
Engine: 350 L98 from 89 vette
Transmission: World Class T5
Axle/Gears: 3.70 Precision Gears
Lowering springs?
I wanted to know where i can get just 2 front lowering springs. I was thinking of just cutting a loop out of the oem springs but have been told that is bad to do?? I am happy with how the back sits and just want to lower the the front. Any ideas or places would be greatly app. I have seen Eibach,Intrax,and progressive but they all are a set of 4.
Old Jan 24, 2003 | 01:13 PM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
Cutting coils is not good, esp for handeling. Since the front end is quite similer to a s10, you might beable get some coils from a 4.3l s10 and give them a try.
However, no matter what you do in the suspension will effect the way it handles.
Truly the best thing though would be get the set of 4 and only put in the two.
Old Jan 24, 2003 | 02:58 PM
redraif's Avatar
Car: 87 Red/Blk Bird loaded 3.4L & 700R4
Transmission: Th700R4
Agreed. I got an Eibach pro kit...I replaced all 4.
An one thing to note... With the Eibach pro kit...my rear did not lower much at all from the stock springs ride height. That was because after 15 years the stock springs have sagged. They are worn out. The Pro Kit is supposed to lower the car 1.5 inches. It maybe lowered mine .5. Again because the old ones were so worn out. If I were you, I would replace them all.
My ride so greatly improved...it was amazing. The Eibachs are progressive, so the keep you from banging around like our stock springs. They have large coils that help contain your range of movement without jarring you. I remember how horrible the railroad crossings were before them...bang,bang, bang...the springs were fully compressing and then springing back to full height and banging me all around, and they were weak with age, so they compressed much easier then they should.
With the eibachs, it is a floaty effect. They have a more controlled compression and release. With them, the larger sway bars, urathane bushings, and subframe conectors...the car is amazing now!
Old Jan 24, 2003 | 10:14 PM
MdFormula350's Avatar
might as well get all fours..
http://www.thunderracing.com/index.c...ategoryid=1071
Old Jan 26, 2003 | 11:58 PM
jcurrieirocz's Avatar
Car: '81 Trans Am
Engine: 6.6L
Transmission: auto 350
you can buy just the front lowering springs here---->http://jcwhitney.com/
Bubbajones_ya
Jul 6, 2024 08:32 PM
Lanz06
Sep 14, 2015 07:16 PM
crzycamaro86
Sep 12, 2015 05:51 PM
Thornburg
Sep 12, 2015 10:11 AM
lakeffect2
Sep 7, 2015 03:52 PM
