plastic seatbelt guide? How to change??
Car: 89 WS6 Formula
Engine: 305 TPI w/ some mods done
Transmission: Modified THM700R4
The plastic pieces that clips into the sail panels that help guide my seatbelts are broke.....not the whole plastic piece just the clips. right now i just glue'd them so the'll stay up. but im removing my headliner and replacing it. How do i replace the plastic peices? Is there an easy way of doing it?...cause i really dont want to take apart the whole seatbelt assemply and slide the belt through.
there is a clip that holds them on. If you use a small flathead screwdriver to push the tabs in, they will come right off. But if you already broke the pieces, then just pull them off, toss them, and buy a new set off of ebay. i got a pait for $7 plus shipping.
They come pre-cut so you can slide the seat belt into them, and then they just snap into place. Once you get a new pair you will see how they work.
Car: 89 WS6 Formula
cool thanx josh. Yeah thats what i thought...but wanted to make sure cause thirdgenresource has them but they didnt look precut. Thanks for the help.
Car: 89 WS6 Formula
yeah just called them an ordered a set....they come precut so im all set. Thank *** too cause i really didnt want to have to pull apart the seatbelt assembly......my luck the damn things would spring back and id never get em to retrack properly..lol. But thanks for your help.
1992 Trans Am
May 10, 2023 07:19 PM
Glowsock
Aug 26, 2015 12:28 AM
