need uner hood pics of TPI to carb swap!!
Old Feb 24, 2003 | 02:15 PM
bluegrassz's Avatar
Car: Camaro
Engine: Carbed L98
Transmission: TH350
need under hood pics of TPI to carb swap!!
I am changing from TPI to carb. What has everyone done with the extra wires? I plan on taking out what I dont need.
I want to see what everyone has done.
Post pics and list your setup (carb, intake, air filter)
thanks.
Old Feb 24, 2003 | 02:24 PM
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
I went from a CC Carb to a non-CC carb and removed my old computer and cut the old harness out.
I did have to wire my VSS wires from the tranny to the VSS buffer since I accidentally cut them off since the speedo wires were in that harness I cut.
Edelbrock 7101 Intake,
Edelbrock 1406 Carb
Edelbrock drop base air cleaner
I then went to TPI, but that is another story.
Old Feb 24, 2003 | 02:46 PM
bluegrassz's Avatar
Car: Camaro
Engine: Carbed L98
Transmission: TH350
Yeah, Im going carb for racing. It wont be a daily driver.
Nice looking setup. Hows the new motor comming???????
Keep pic comming guys. This is just the info I need.
thanks Zepher.
Old Feb 24, 2003 | 03:49 PM
johnsjj2's Avatar
Car: 1991 Z-28
Transmission: T-5 (gonna buy the farm)
Here are mine:
Attached Thumbnails need uner hood pics of TPI to carb swap!!-dirtyengine1websmall.jpg
Old Feb 24, 2003 | 06:52 PM
Zepher's Avatar
Motors coming along slowly, but surely.
Going to drop it in this week just to clear up space in the garage since another LT1/4L60E is on it's way to my house to be installed in my friends 82.
Old Feb 25, 2003 | 07:50 AM
bluegrassz's Avatar
Car: Camaro
Engine: Carbed L98
Transmission: TH350
Originally posted by johnsjj2
Here are mine:
How is the alternator mounted. I kinda like that setup. Can you tell me more about it? Nice and neat engine bay. Only what you need. I like that.
Old Feb 25, 2003 | 07:51 AM
bluegrassz's Avatar
Car: Camaro
Engine: Carbed L98
Transmission: TH350
Good luck on the install.
Old Feb 25, 2003 | 08:13 AM
Blackroc86's Avatar
Car: 1986 Iroc
Engine: 454 Demon 850DP
Transmission: TH350, 3500 stall
Here is my swap when it was partially done.
Old Feb 25, 2003 | 11:40 AM
Zepher's Avatar
Thanks, I am going to need it.
This is going to be the first time that I put a motor in.
Old Feb 25, 2003 | 11:47 AM
bluegrassz's Avatar
Car: Camaro
Engine: Carbed L98
Transmission: TH350
Didnt you pull the other one out? Its just reverse procedure.
The hardest part it hooking back up the wiring, which is not to bad if you marked it. When I put my tpi in, I plugged everything in on the motor, then set the motor in. Then everything else went to the fire wall or light, or other accessories like the wiper motor.
Just take your time and you will be ok. keep a good haynes or chilton close and some good help.
Frozer!!!
Jan 19, 2024 04:55 PM
midge54
Jan 29, 2017 07:00 PM
86IROC112
Aug 17, 2015 02:00 PM
Sanjay
Aug 12, 2015 03:41 PM
